INFO: 65 Mustang Floor Pans Work on 1972+ Torinos |
Page <12 |
Author | ||
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14215 |
yes this is the thread i was referring to! carl, can you throw a sticky on this!!!
Regul8r 2 ![]() Admin Group ![]() ![]() Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
DONE
Owner- www.CaNDeCustoms.com |
JFN ![]() New Member ![]() Joined: 23-January-2022 Location: Du, Status: Offline Points: 3 |
So did the original rails for the front seat fit back in place or did you have to modify the rails to make the original seat fit?
hogfiddles ![]() Senior Member ![]() ![]() Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1108 |
you need to re- install the seat-rail supports that go across the top of the floorpan.
r9b2 ![]() Member ![]() Joined: 16-June-2021 Location: Maine Status: Offline Points: 49 |
Just wanted to throw in some more evidence of this working, if that's okay with you guys. It took a long time because of the base Auto Hobby shop only being open two days a week, but I threw both sides of '66 Mustang floorpans in my '73 Torino. ![]() After: ![]() |
1973 Ford F100 429 1966 Ford Mustang I6 2017 Ford Expedition |
Compton ![]() Senior Member ![]() Joined: 22-April-2017 Location: Auckland Status: Offline Points: 474 |
Might as well jump on the bandwagon and second that…however I used 71-73 as they don’t have the holes for the seats to bolt through so one less thing to weld up or plug
![]() ![]() ![]() Full left and right pans were used which basically dropped straight in and then stitched into the footwell |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 4959 |
Thanks for posting these pics guys, much appreciated.
Wayner315 ![]() Member ![]() ![]() Joined: 19-October-2021 Location: Alberta Status: Offline Points: 92 |
Thanks for these pics. I might have ordered those ridiculous Torino patch panels sold everywhere but this seems much better.
just an update on the pans...originally got a set of coupe/fastback and a set of convertible as they're slightly different...Chopper test fitted both and went with the convertible as they fitted better...
RacerJames ![]() New Member ![]() ![]() Joined: 25-April-2022 Location: 86401 Status: Offline Points: 20 |
This is very cool!
Made me wonder if maybe the '79 and up LTD/Crown Vic floors would work as well?
'73 Torino Stock Car
'71 Mustang Stock Car 351C powered |
I bet you’ll be the first to know, and report how to do it ;) Dfox
Fortunately for me, I live in rust-free AZ. I never knew what this meant until I relocated from SLC. Its a world where rubber and plastic disintegrate, but steel remains unchanged. I could probably supply a rust free car that someone could then experiment with!
72MLC ![]() New Member ![]() Joined: 10-December-2021 Location: Memphis Status: Offline Points: 16 |
I cannot find anyone here local for work or advice, so may have to get a friend to just dive in and help eventually. I have the pans but where do you find the seat floor supports? Or were they fabricated? Only can find one website and it's a non secure one, so looks like a no no. Thanks!
Chopper fabricated a hybrid seat brace from factory (over the drive tunnel) and new as I’m using 69 Mach 1 seats…you can use the factory brace you just have to set the pans to the lower height of the brace…
Thanks! Finally found a place today accepting work, so looks like I should be getting on the books sometime tomorrow.
Page <12 |
