  New Posts New Posts RSS Feed - INFO: 65 Mustang Floor Pans Work on 1972+ Torinos
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 11:34AM
yes this is the thread i was referring to! carl, can you throw a sticky on this!!!
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 1:13PM
DONE
Owner- www.CaNDeCustoms.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 1:53PM
DONE
Clap good because you know how often this subject comes up, plus it may be easier for new guys to find! Wink
JFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JFN Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2022 at 2:04PM
So did the original rails for the front seat fit back in place or did you have to modify the rails to make the original seat fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2022 at 4:23AM
you need to re- install the seat-rail supports that go across the top of the floorpan.
r9b2 View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote r9b2 Quote  Post ReplyReply Direct Link To This Post Posted: 13-March-2022 at 4:13AM
Just wanted to throw in some more evidence of this working, if that's okay with you guys.  It took a long time because of the base Auto Hobby shop only being open two days a week, but I threw both sides of '66 Mustang floorpans in my '73 Torino.
After:
1973 Ford F100 429
1966 Ford Mustang I6
2013 Subaru Forester
Compton View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 13-March-2022 at 8:42AM
Might as well jump on the bandwagon and second that…however I used 71-73 as they don’t have the holes for the seats to bolt through so one less thing to weld up or plug
Full left and right pans were used which basically dropped straight in and then stitched into the footwell
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-March-2022 at 10:29AM
Thanks for posting these pics guys, much appreciated.
Wayner315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayner315 Quote  Post ReplyReply Direct Link To This Post Posted: 14-March-2022 at 3:08AM
Thanks for these pics. I might have ordered those ridiculous Torino patch panels sold everywhere but this seems much better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2022 at 1:09PM
just an update on the pans...originally got a set of coupe/fastback and a set of convertible as they're slightly different...Chopper test fitted both and went with the convertible as they fitted better...
RacerJames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2022 at 11:43AM
This is very cool!
Made me wonder if maybe the '79 and up LTD/Crown Vic floors would work as well?
'73 Torino Stock Car
'71 Mustang Stock Car
351C powered
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2022 at 1:40PM
Originally posted by RacerJames RacerJames wrote:
This is very cool!
I bet you’ll be the first to know, and report how to do it ;)
Dfox
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2022 at 4:39AM
This is very cool!
Dfox
Fortunately for me, I live in rust-free AZ. I never knew what this meant until I relocated from SLC.
Its a world where rubber and plastic disintegrate, but steel remains unchanged.
I could probably supply a rust free car that someone could then experiment with!
351C powered
72MLC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72MLC Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2022 at 7:18PM
I cannot find anyone here local for work or advice, so may have to get a friend to just dive in and help eventually. I have the pans but where do you find the seat floor supports? Or were they fabricated? Only can find one website and it's a non secure one, so looks like a no no. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2022 at 8:36PM
Chopper fabricated a hybrid seat brace from factory (over the drive tunnel) and new as I’m using 69 Mach 1 seats…you can use the factory brace you just have to set the pans to the lower height of the brace…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72MLC Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2022 at 4:43PM
Thanks! Finally found a place today accepting work, so looks like I should be getting on the books sometime tomorrow.
stumpnc View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote stumpnc Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2023 at 6:40AM
Did you use the left pan on the right and vice versa as mentioned above?
I ordered a set this morning for my 73 Ranchero project
Any pointers much appreciated!
