  New Posts New Posts RSS Feed - INFO: teardown vids
INFO: teardown vids
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Topic: INFO: teardown vids
    Posted: 27-September-2020 at 7:06AM
one thing i caught, dude says all output shaft speedo drive gears are the same, AFAIK there are 3 different tooth counts cut into the steel shaft.
some rear gear / tire size combinations are not correctable with the driven gear so you need to start with a suitable tooth count for your application
and another
Edited by Rockatansky - 27-September-2020 at 10:37AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2020 at 12:37PM
Thank you for posting this Rock! Yes, 3 different spline counts, 7, 8 and 9. I do know the long tail shaft C6's have 7 splines/grooves for speedo gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2020 at 4:31AM
The guy's son was getting ripped pretty good by builders who specialized in racing applications. The young man kept saying how they were wrong and his dad is the best ever. It was humorous to say the least.
   There are definitely many good builders out there and the videos are a wealth of knowledge.
   Building a trac-lok 3.25 9"  with guidance from a guy named Tom on YouTube.  Well done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2020 at 12:23PM
Thanks for posting these Rock.  I made them stickies.
Bueller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bueller Quote  Post ReplyReply Direct Link To This Post Posted: 03-January-2021 at 9:06AM
I follow these guys on YouTube..the old man is pretty knowledgeable, but I agree with you guys...there’s a lot of other good builders out there and not really necessary to trash talk the whole time.
Would like to see some assembly videos from them. Seems like most of their vids are disassembly or Chevy videos
Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2021 at 7:36AM
AODE/4R70W teardown
