Instrument cluster lens? |
Anderslober
Senior Member Joined: 30-July-2019 Location: Denmark Status: Offline Points: 764 |
Posted: 28-February-2023 at 6:53AM |
Hi forum. What do you fellas do for new lenses in instrument cluster on 70 Cylone?
Have any of you tried to polish the lenses? If so, what did you use? Thanks. Edited by Anderslober - 28-February-2023 at 9:22AM |
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 614 |
Check "How to" section, Instrument cluster screen Refurb, discussion there on what people have used.
Dave - 1973 GTS N code
Anderslober
Thanks. I will try some PlastX or acrylic polish……hopefully does it. The lenses are a bit yellowed too….
72 RS 351
Almost all plastic used on instrument clusters can be polished easily with typical mild car polishes. Start with a mild polish, avoid anything that you can feel the grit in, such as most compounding products. I have plastic cased comic book containers, the plastic is fairly tough, but I have been able to remove any scratches from them, light or deep. A tough plastic can take a real compound, but only apply it by hand. Use a soft cloth like a face cloth, terry cloth etc. it works great on the instrument cluster covers.
Compton
Senior Member Joined: 22-April-2017 Location: Auckland Status: Offline Points: 629 |
Autosol makes a plastic polish that works well…I’ve found that using their metal/chrome polish first then the plastic polish gives the best results
