intake and carb swap |
Post Reply
| Author | |
orangedeath
Joined: 03-February-2004 Location: United States Status: Offline Points: 3 |
Quote Reply
Topic: intake and carb swapPosted: 03-February-2004 at 10:40AM |
I have a totally stock non-CJ 429 and im thinking about swapping to an edelbrock performer RPM and an 850 demon (i have a 780 holley right now, and im going to be putting in a cam and heads later, hence the hugeish carb). however all i've really done on my car is change the oil and tune it up. What do i have to do for an intake a carb change? it can't be that hard, but i really dont want to screw anything up |
1970 Torino GT / N-code 429 / toploader / 3.50 'niner / Competition Orange
capt.b-1
Quote Reply
Posted: 11-February-2004 at 1:00AM |
there are some things to consider with your intake/carb swap. as far as carb size, the 850 should be fine, although it wouldn,t hurt to have a good set of dual exhaust on the car. your going to need that with the cam and heads anyway. the intake swap is a fairly straightforward job. make sure your existing fuel lines and carb linkage/kickdown rod will work. it wouldn't hurt to have a timing light handy. good luck |
orangedeath
Quote Reply
Posted: 15-February-2004 at 5:27AM |
thanks capt. i forgot to say i already have headers and duals, but im planning on going to a 3 inch system with x-pipe |
Post Reply
| Tweet |
