  New Posts New Posts RSS Feed - interchange help
interchange help
69fastford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69fastford Quote  Post ReplyReply Direct Link To This Post Topic: interchange help
    Posted: 25-October-2007 at 12:51PM
i have a 1970 mustang with disk brakes and a 9 inch rear.will any of this stuff work on my 69 fairlane? any help would be appreciated. thanks mark
erics69cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote erics69cobra Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2007 at 12:55PM
Hi Mark, I don't know if you found any help yet but many parts will interchange. If you still need help with this email me with what parts you want to know if they will work my email address is ericd4027@yahoo.com
ERIC
stuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stuck Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2007 at 3:45PM
    check your tie rods compare the size of the nut the 70 mustang had larger tie rod/hole in spindle.if you can swap nuts you can swap spindles presto disc brakes.for the 9 compare ujoint size or drive shaft lengths , measure guide pin hole center of u bolts.on your back looking up.if you need help holding measuring device remember theres a dumb guy end and smart guy end.can i have your leftovers.
Edited by big8big472 - 23-December-2007 at 4:29PM
michigan
