  New Posts New Posts RSS Feed - Keep C4 or other options?
r9b2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r9b2 Quote  Post ReplyReply Direct Link To This Post Topic: Keep C4 or other options?
    Posted: 02-August-2022 at 6:47AM
Hey all, the time is near to throw my rebuilt 351C 4V into my Torino.  Car came stock with a 250 I6 and a C4 automatic.  My research shows that it probably has a 157 tooth flexplate and that the V8s would have come with a 164, so I'm not sure if this is a simple bolt-together or not.  Is the C4 worth keeping and possibly modifying, or should I explore other options?  I'm not against a C6 or something like that, but my headers are allegedly for a C4 trans.
1975 Ford F150 300I6 4spd 4x4 Project
1973 Ford F100 429
1966 Ford Mustang I6
2025 Subaru Forester
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2022 at 1:37PM
157 tooth and a 351 leaves just barely not enough room for the stock starter.
you can use a smaller 'mini-starter' but that requires some wiring changes
also consider that your I6 C4 is not the same internally as a V8 C4, smaller clutch packs in the drums and probably fewer planet gears in the planetary gear sets
This page was generated in 0.055 seconds.
