Keep C4 or other options? |
r9b2 ![]() Member ![]() Joined: 16-June-2021 Location: Maine Status: Offline Points: 49 |
![]() ![]() ![]() ![]() ![]() Posted: 02-August-2022 at 6:47AM |
Hey all, the time is near to throw my rebuilt 351C 4V into my Torino. Car came stock with a 250 I6 and a C4 automatic. My research shows that it probably has a 157 tooth flexplate and that the V8s would have come with a 164, so I'm not sure if this is a simple bolt-together or not. Is the C4 worth keeping and possibly modifying, or should I explore other options? I'm not against a C6 or something like that, but my headers are allegedly for a C4 trans.
1973 Ford F100 429 1966 Ford Mustang I6 2017 Ford Expedition |
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5637 |
157 tooth and a 351 leaves just barely not enough room for the stock starter.
you can use a smaller 'mini-starter' but that requires some wiring changes also consider that your I6 C4 is not the same internally as a V8 C4, smaller clutch packs in the drums and probably fewer planet gears in the planetary gear sets
