  New Posts New Posts RSS Feed - lowering spring options
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Topic: lowering spring options
    Posted: 04-May-2025 at 5:56AM
Has anyone tried the Hotchkis lowering springs that they market for 65-66 Galaxies?  I’m looking for pictures of 72-76 Torinos with them installed. Or Eaton 2” lowering springs. Exploring options to lower my 72.
Thanks.
Edited by n2fordwagons - 04-May-2025 at 6:04AM
Jeff
72 base Torino (modified)
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2025 at 2:42AM
Other than Comptom's restomod project, which isn't complete, I don't know of anyone else on the forum who have used them.
If you do end up using them, post pics.
Alternatively, you could use something like the CVPI springs and cut them to the stance of choice.  Of course you can't do that for the rear springs.
Post Options Post Options   Thanks (1) Thanks(1)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2025 at 6:27AM
Vince, not to be argumentative, it is a bit more involved but one can cut a set of rear springs and reform the ends of the rear coil springs. I had to for my Ranchero, since no one at the time had the needed/wanted height and/or spring rate options. My front springs are actually '99 Ford Lighting coil springs cut down to an overall height of 10.75", so I had to come up with a set or rear coil springs that no one had as an option. I do not want to say heating any active coils is a good thing even though I did that on my first vehicle(it was fun removing highway reflectors), but I did cut the rear coil about 1/2 to 1 full coil with an angle grinder/cut off wheel, then used an Oxy/Act torch to heat and help reform the inactive coil "pigtail" that locates the spring, either in the upper or lower portion. Again, this is just an option, but my set have been in service since '11 or so with no breakage or sagging. I believe I did choose a "lighter" Thunderbird rear coil spring prior to cutting so the spring rate wouldn't be too bad or ride too rough. Hope this is helpful
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 3:31AM
I put a complete coil over set up in the front
of my 75 , love the ride and adjustability!!
I’d post pics but this site is too technical for this old guy !
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 4:06AM
Great to hear from you. I’ve been thinking about doing this, since we discussed it years ago at the Moonshine Festival. I’ve got a spare set, so will definitely give it a try.
Edited by n2fordwagons - 07-May-2025 at 1:32AM
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 11:30AM
Not argumentative at all!  I forgot that you had done the custom lowered rear springs on your car, so yes I agree it's totally possible.  It's just not always feasible for all people as it requires more skill and is a bit more involved than just cutting the front coils.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 11:31AM
What coilovers are you running?
DJsTorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJsTorino Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 2:08PM
Thanks.
I've got the Eatons in the rear of my car but I think its just an inch lower. I know I got their fronts and cut 1.25 coils out to lower the front. I've been very happy with the Eatons
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 3:59PM
PMT Fabrication
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2025 at 1:25AM
Thanks.
Thanks.  My biggest concern is spending almost $400 on a pair of Eaton springs, and not getting the desired drop.  Which is why I'm hoping someone with experience with them can chime in with pictures.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2025 at 6:45AM
Here’s the final result.
I used new Lesjofors 4127521 springs on the front, cutting a coil.
On the rear I used a pair of springs from my 73 Torino sedan parts car.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2025 at 1:50PM
That's a great stance, the height and tires fit really well. Thanks for the pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2025 at 8:35AM
The stance looks awesome.  What is the application listing for those coils?  Any specs on them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2025 at 8:14AM
Thanks.
I found them on RockAuto over six months ago, searching for:
Rockauto doesn't list them any more.
However, it lists the following applications:
FORDFAIRLANE1966-1970
FORDRANCHERO1969-1971
FORDTORINO1968-1971
MERCURYCALIENTE1966-1967
MERCURYCAPRI1966-1967
MERCURYCOMET1966-1969
MERCURYCYCLONE1966-1971
MERCURYMONTEGO1968-1971
I couldn't find any specs on them.
Jeff
This page was generated in 0.080 seconds.
