Manifold bolt? |
Page 12> |
Anderslober ![]() Senior Member ![]() ![]() Joined: 30-July-2019 Location: Denmark Status: Offline Points: 319 |
![]() ![]() ![]() ![]() ![]() Posted: 22-July-2022 at 8:22AM |
Hi forum…qq…exhaust manifold…right side…..is there supposed to be a bolt on one side where the exhaust pipe hooks up?
I had a great fight today…..still havent won!😵👍
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5637 |
should be 2 studs / nuts
Ok. Thanks. Someone drilled a hole for a bolt then. The other studs are not in great condition. Can they be removed and changed?
this is the Dorman number that pops up on Rockauto for our exhaust manifolds but there may be longer studs available so check what length will work for you, and verify the method of obtaining that measurement. or you may be able to source some locally?
https://www.rockauto.com/en/moreinfo.php?pk=1261582&cc=1129306&pt=13936&jsn=570 Edited by Rockatansky - 23-July-2022 at 5:41AM |
Wow…wax…who knew!👍 I will see what I can do.
Here are some pictures my cars’ right manifold….
Another pic….
And another…(I still dont know how to upload more than one photo in a post)
handsofstone ![]() Senior Member ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3461 |
Just repeat the download procedure before you post reply and they will all be in the same place.
Ssshhhhuuuuccckkkss! I tried to take of the right exhaust manifold. All went well, until the very last number one cylinder upper bolt….snap…..
Anyway….maybe still possible to get the bolt…..will post…
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2083 |
Tip, just barely brake loose all related bolts before fully loosening any of them. The extra pressure from having some bolts out adds slightly to the others.
73 Ranchero Sport "72 front end", floor shift/console, planning EFI 7000rpm 351-4V &4R70W 73 Ranchero GT 351C-4V 3.70 gears for sale later. 92 Lincoln Mark VII SE, OBDII 347/4R70W |
are you working the bolts back & forth (tight / loose) and lubing as you go?
1st move should be in the tight direction, then check it in the loose direction. smack the bolt head with a hammer and test each direction again. a 1/2" breaker bar with a quality 6 point socket is the way to go, a metric socket that fits tight beats a loose inch socket every day of the week ![]() Edited by Rockatansky - 27-July-2022 at 11:36AM |
A six point with the little grooves at the angles will be the best bet adding to what Rock posted. Especially if they are slightly rounded off.
Those socket and wrenches with the rounded corners used to be a Snap-On invention. Now even the cheap China tools have them.
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 4174 |
radiused corners don't really help the bolt come loose, Snap-Off patent was to reduce stress risers and broken sockets/warranty costs. They have dazzled everyone with bullsh*t about "Flank drive" for years.
I was very careful during the operation. Yes….I slightly tightened first….then loosened…back and forth…carefully…used a full can of wd40 type fluid.
The last bolt was just unlucky. The bolt looked different than the others. Greyish burnt and rough.
probably chinesium
If I am unable to find a right side manifold…..what is a good way to fix the drilled hole for the stud? Ideas welcome.
The manifold looks really good otherwise.. ![]() |
There are repair items made to replace a broken and seized stud etc. Find those and see if they will fit onto that one side. The one I'm thinking of is like a pair of steel bars that attach by long bolts of their own, sandwiching the ear of the collector and lower flange. Kind of like a clamp, it squeezes the old flanges(the small section where the bolt is) together with the down pipe flange. They are on Amazon and I think they were about a $25 item. I believe it requires a decent flat surface on both parts to clamp onto, but you can grind and file down that worn hole area to do that.
exhaust manifold split repair flange search results, images |
That's a large variety of repair solutions for broken or stripped manifold studs and bolts. This is the type I was thinking of. I thought it clamped the two parts together, but it just replaces the manifold stud with an interesting loop of steel;
Get a straight torch tip and burn out the stud. Tap the threads. Put the rest of the bolts back in first. If the manifold hasn't moved, it will still be sealed to the head.
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14215 |
its drilled out...i's rethread it, or if needed drill it larger and helicoil it to the correct size, or since there's room use a bolt that is long enough to go down towards the pipe (grind part of the bolt head to fit against the manifold
I got the right exhaust manifold off today. No bloody gasket!
Manifold looks good. Except the drill out hole…
Ford didn't use gaskets on the X manifolds
Wow…ok….that means this is original and untouched basically.
I think I will put in a gasket though….
Whadyasay fellas..?
Just need an angled washer now….. ![]() |
Run a tap and use a heli-coil (there is a better coil replacement system but I forget the name). That setup will work but you already have the manifold out so why not do the other one as well?
Page 12> |
