Mexican 302 |
kversch
Senior Member Joined: 02-December-2009 Location: New york Status: Offline Points: 1399 |
Posted: 04-November-2010 at 11:18AM |
so the 73 4door we parted out had a 302 in it, the guy told me it was a 69 302, he said its supose to be a Mexican boss. I started doing a little diging around and am slowing finding there was such a thing. didnt know that before. its also called a mexican 302 in some of the things I have read.
" The block was a high-strength, higher nickel content design made in Mexico. "Hecho en Mexico" casting marks are present in the lifter valley, and its main strength was the appearance of much larger and stronger two-bolt main bearing caps on the engine's bottom end" "This engine block is considered the strongest production 302 block other than the Boss 302 and the Trans Am 302. It is considered to be on par and equal in strength to the K-code HP 289 block. The heavy duty Mexican 302 block was produced for several more years, and even showed up on Ford trucks and vans throughout the late 1970s and early 1980s."(http://en.wikipedia.org/wiki/Ford_Windsor_engine) so does anyone know anything about these engines? my hope for this winter is to get this engine at least cleaned up and running maybe even painted up nice to go in to the black 73 GTS. I would like to build it up nice and make it work until i can come up with a 351C or a 429/460 bb to go in it. |
-kevin-
Brown 72 gran torino 351c 2v Black 73 GTS FB 302 Red 73 GTS FB 351C C6 trans 73 GTS FB Parted 73 torino 4dr, 302, FMX parted 97 F250 crew cab 7.3 diesel http://kverschtorino.blogspot.com/ |
Blueoval76
Senior Member Member of the Stroker Club Joined: 20-February-2010 Location: Sussex WI Status: Offline Points: 698 |
Yes I had one in my 66 Ranchero. I found out it has a little taller deck thicker main caps and thicker stronger all around motor. It does also have higher nickle content and is equiv to the 289 HI-PO. I know a circle track racer that was running one at 7500rpm+ and to me that is impressive for a 302 in that environment. It is a great motor and highly sought after because its stronger on a budget. Build the snot out of it!! It will take alot more abuse than a standard 302 will. Here is a blurry pic of my valley...
There is also supposed to be something thicker by where I have the ground hooked up area...
03 Bonneville some mods |
