  New Posts New Posts RSS Feed - modern instrument panel for 71 torino
weaverT1971 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Topic: modern instrument panel for 71 torino
    Posted: 13-July-2014 at 2:58PM
Hey all.......So I would like to install a more modern looking instrument panel in my 71 Torino. But I have a few questions....first what is that tape looking stuff on the back of the instrument cluster? And what does it do? Also it would seem like it would be kind of a pain in the ass to put after market gauges in because it looks like the only gauge thats plug and play is the speedo? any thoughts...thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2014 at 5:26PM
the tape looking thing is a printed circuit board, it's basically your wires to the gauges and lights
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2014 at 12:54AM
Yeah I looked around a bit and found that out....but how would you incorporate that if you wanted to put a retro gauge cluster in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2014 at 10:55AM
Well, you wouldn't. You would set up a harness for all your gauges and tap into the appropriate wires that would have fed the printed circuit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2014 at 12:10PM
Yeah, I figured as much...so I have a wiring diagram on the way....Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2014 at 1:55PM
probably the trickiest part will be the fuel gauge you need the proper resistance range to match the fuel sender in the tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2014 at 10:12AM
i'm not sure exactly how much after market you're looking for ? you might check out a co. called dakota digital, they can custom fit their gauge unit to your dash cluster
This page was generated in 0.069 seconds.
