  New Posts New Posts RSS Feed - More paint help
More paint help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Topic: More paint help
    Posted: 01-June-2015 at 4:26PM
Bumper Chrome.
how do I paint it?
I am cutting, welding, sectioning and tucking.
I don't want to send it out to rechrome so looking at painting it the bright silver and should look good.
So, HOW do you prep it for paint and what do you use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2015 at 5:23PM
after all the welding, etc. i'd sand blast it to "rough up" the chrome, then any body filler if needed, then a couple of coats of good self etching primer like PPG DP or omni, then a coat of 2k sandable primer to sand smooth, then paint Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2015 at 5:39PM
I like sand blasting myself, especially if painting over chrome.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 2:44AM
Yep. You have to remove the chrome/nickel plating to get proper adhesion. Unfortunately, that spray coating does not last under normal wear and tear. I've used every brand, and it looks great at first, but then degrades. A better choice is powdercoating. Todd (White Lightning) powdercoated his bumpers and they looked fantastic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 5:54AM
Powder coater will not touch it. Says the weld will show through.
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 8:52AM
Years ago, I helped a buddy paint his bumpers. I think I remember him stripping the chrome plating off, and I think he used some sort of low grade acid like muratic acid, or something like that. The chrome pealed of in large flake pieces with a putty knife. Then, we just sanded, smoothed, primed, and painted. But again, this was YEARS ago. But I do remember he removed the chrome plating.
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
NwOh_Starsky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 9:39AM
Carl,
I was going to bodywork my bumpers, them do a chrome vinyl wrap on them.
Just an idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 1:55PM
Belt sander (Yikes!!!) with a fairly fine paper. Do NOT let it sit/stop in one place. strip the chrome/nickel, bodywork the bumper, then paint to match or contrast the body. (Or, paint metallic silver like a lot of guys do with their fiberglas bumper skins.)
Muriatic acid (20% hydrochloric) will not strip chrome (at least, not very fast/well) as I use it to get rust off my bumpers and the chrome is still hanging in there.
Carl, Paint to match your wheels and tie the colors together Cool
Edited by Big Bird - 02-June-2015 at 2:15PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 2:53PM
That's my thought!
Bumpers, wheels, tail light framing.
Possibly EVERYTHING that is polished aluminum, chrome, or pot metal ALL done in the Silver Frost color from the wheel I painted before I sent them off to be powder coated.
They will SHINE and have metallic. YEAH you will know they aren't chrome but hey, they will tie it all in and look good I THINK/HOPE! Especially after chopping, cutting, sectioning and welding the bumpers.
Here is the Powdercoated wheel...
here is the one I painted that Silver Frost(over gray primer) color as a comparison, it was the BRIGHTEST silver I could find and would be the color I use on the bumpers, taillights and other trim pieces...
Edited by Regul8r - 02-June-2015 at 3:10PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 5:28PM
carl, if you want to power coat or rechrome them after welding you would need to make sure the cuts are lined up as best as possible, weld then grind down flat so it is as close to looking like it is one piece (basically you'd be shaping and filling with weld) i grind the welds down with a 4" angle grinder leaving them about 1/32" above level, then grind them down further with an angle die grinder with a roloc disc to shape and blend the metal like sanding body filler to it's desired shape, same idea but using welds as your filler! it's a lot of work but it can be done (if you look in my thread... the wiper cover i made was done that way...it's made from seven different pieces of metal)
