  New Posts New Posts RSS Feed - Motorcraft Engine Coolant
spriegel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Topic: Motorcraft Engine Coolant
    Posted: 19-July-2024 at 7:54AM
Hi Everyone,
Does anyone have the Motorcraft part number for Engine Coolant for our Torino's?
I'd like to do a flush, and wanted to replace w/ Motorcraft fluid.
My 1973 Ford Gran Torino owners manual lists:
Ford Part Number:  8A-19549-A, B
Ford Specification:  ESE-M97B18-C
I stopped by the Ford parts store and their database only goes back to 1980 and they had several different types of coolant (specs, colors, etc).
Thanks,
Fairview, PA
'1973 Ford Gran Torino
Post Options Post Options   Thanks (1) Thanks(1)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2024 at 10:49AM
If you can't find a Motorcraft coolant, I've been getting my coolant at O'Reilly. They sell a house brand traditional green coolant in 50/50 mix. It's not the "compatible with everything" stuff like is all I can find at Walmart or AutoZone.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2024 at 2:59PM
Walmart has the best priced anti-freeze, it's about $12 for a concentrated full gallon, Prestone. That will work in almost everything, and the old Fords I recall took about two gallons, half of a four gallon capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 20-July-2024 at 1:38PM
Thank you everyone for the help.
Fairview, PA
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-July-2024 at 1:27PM
Chris, I don't know the Ford part number for the green coolant, and I am not sure if Ford even carries it anymore.  However, as others have said, just got to a parts store and get the traditional green coolant.  Like Inkara says, not the "any make and model" stuff, this is the non-long life green stuff.  I typically by the non-premixed stuff and jugs of de-ionized water, and pour in at a 50:50 ratio.   Once you pour half a jug of each, mix the two together in a jug and then you have 50:50 for top ups.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 21-July-2024 at 1:52PM
Thanks Vince, and all - I was reading up on the different types of coolant and the Ford parts store said the different colors have different properties.  They do have two versions of the Ford Motorcraft Green and said they would call me back this week with details - I'll share what I find out.
I did find this Ford chart on their Ford Parts page but it only went back a couple of decades, but it highlights the Green > Yellow > Orange history over the years:
My '73 manual said not to use ethanol or methanol antifreeze or to mix it.
It's good to know the traditional green coolant is the way to go and the available stores with different brands, thanks everyone.
Thanks,
Fairview, PA
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-July-2024 at 2:53PM
Chris, from that chart, you want the Green Coolant, used on the 2001 and older cars.  I worked at GM when Dexcool came out and I remember how much of a pain it was to have this "new and better" coolant. You had to make sure you didn't mix the two and use the correct stuff depending on the model and year.  Prior to that, every car, at least American cars, used the same green coolant. As you change the green stuff regularly, it works great IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2024 at 11:43AM
As follow-up to this post, my Ford Parts dealer found the green coolant.
Motorcraft Premium Pre-diluted Antifreeze/Coolant
Part Number:  VC5DIL
They said they can order it anytime I needed it.
Fairview, PA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2024 at 10:30AM
I hate the over-priced pre-diluted antifreeze, but I get it. getting another empty jug and cutting a gallon of concentrate is too much for the non-car folk in the modern era and they make it easy.
I get traditional green at Menards brand unreduced or Walmart. Hold-out for Prestone.
Menards is great, decent price and 11% rebate.
Then buy a gallon of distilled water and good to go.
I made the mistake on my GTS for years using tap water...and then not flushing my coolant system for 5-6 years. My coolant was a nasty rusty mess.
One of the reasons I am probably now having to do a heater core this weekend!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2024 at 2:04PM
I like Prestone from Walmart, it was about $11 last time I got a couple. I keep 2-3 gallons of distilled water all the time, all grocery stores carry it. I have high end Amsoil coolant and a few BMW gallons to use for better engines. Those brands are over $20 a gallon too, and they are not diluted yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2024 at 3:12PM
*Sigh* I remember when I would buy gallons of undiluted green antifreeze for $4/gallon at Advanced Auto Parts years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 14-September-2024 at 3:33PM
Yep, that was a change from an explosion of some big plant pushing up the demand, the price. Then it never dropped back. Now it's inflation, the new new normal everywhere. SighErmmErmm
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 15-September-2024 at 12:16PM
The Ford parts department said they also carry the concentrated Motorcraft coolant, part number is just P/N VC-5 (Ford Motorcraft Premium Concentrated Anti-freeze/Coolant).
Fairview, PA
This page was generated in 0.105 seconds.
