  New Posts New Posts RSS Feed - MSD conversion
MSD conversion
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Topic: MSD conversion
    Posted: 30-April-2023 at 5:36PM
Just wanted to say thank you for the MSD discussion topic guys...
I am converting from my worn out durapark ignition over to the MSD setup. I have been overly hesitant to step up to a full MSD system but I am parting ways from my reservation of absolutely keeping the duraspark on my 351C.
I just wish I understood what FoMoCo was thinking with the 72-early 73 cars and the Positive ground versus the 74-79 cars on the tach. Sitting here trying to make sure I get the correct tach driver for this.
Really sort of annoying.
I was debating about keeping my duraspark ignition box but after 27+ years...it's time to upgrade to new system.
I just wish I knew if I should remove the original resistor wire or leave it alone.
one would think I have no reservations about changing my wiring yet again...but man, I just don't want to mess up and fry stuff.
Edit:
Now that I recalled why I made this post: Ignition coils.
TFI EEC IV coils, versus the traditional coil. I was considering using the more modern type coil from 92-96 F series trucks.
Specs on the stock motorcraft and the MSD look comparable.
Plus...this will sound really stupid but I HATE the red color.
I am searching the ole interwebs on what I need to do converting over to the TFI coil, but if anyone has advice, just wanting to avoid mistakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2023 at 12:19AM
Andy,
 If you hate the MSD red, tape off the terminals and paint the MSD distributor cap Ford blue engine paint-I found VHT paint works best(or whatever color you desire), I've been doing that for a while since using Accel dist caps(they have brass terminals)don't like the tan color Big smile. The TFI coils require full 12V at start and in run. When I cobbled together my ignition system, I used the original resistor wire to trigger a relay that sends 12V to my TFI coil, even with reduced voltage output it still energizes the relay and can easily be converter back if later in life you want an all Duraspark ignition. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2023 at 9:26AM
I wish you well with the ignition system, that seems to be an issue for most of the older cars. I never had trouble with mine in the 70's and 80's when I sold my 72.
I have the Mallory system parts I bought when I was young and had my 72, but I never installed the Hyfire IV box, or the coil. I liked the Unilite distributor, but ages later people bashed them. I kept that too when I sold the car, I intend to put all of those on one of my 351C's.
I'm watching with interest for more good news about what works these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2023 at 11:49AM
maybe the 1st time i've heard it referred to as positive ground? what it does is the coil power flows through the tach, thus only 2 wires In & Out. the later 3 wire tach is similar to aftermarket tachs that use switched 12v power, a coil + signal wire and ground. i don't believe there is a way to use the Ford 2 wire tach with MSD? either swap out the 2 wire tach for a later 3 wire or get the 2 wire tach converted by a gauge outfit with an aftermarket make-it-happener
Greg73Oregon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2023 at 10:16AM
This is an easy circuit to put together to supply full +12V to coil and ignition modules.  The relay can be any general-purpose automotive relay (such as labeled "Ignition" or "Headlight", etc.).
GKF
