MSD conversion |
Eliteman76 ![]() Admin Group ![]() Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 4870 |
![]() ![]() ![]() ![]() ![]() Posted: 30-April-2023 at 5:36PM |
Just wanted to say thank you for the MSD discussion topic guys...
I am converting from my worn out durapark ignition over to the MSD setup. I have been overly hesitant to step up to a full MSD system but I am parting ways from my reservation of absolutely keeping the duraspark on my 351C. I just wish I understood what FoMoCo was thinking with the 72-early 73 cars and the Positive ground versus the 74-79 cars on the tach. Sitting here trying to make sure I get the correct tach driver for this. Really sort of annoying. I was debating about keeping my duraspark ignition box but after 27+ years...it's time to upgrade to new system. I just wish I knew if I should remove the original resistor wire or leave it alone. one would think I have no reservations about changing my wiring yet again...but man, I just don't want to mess up and fry stuff. Edit: Now that I recalled why I made this post: Ignition coils. TFI EEC IV coils, versus the traditional coil. I was considering using the more modern type coil from 92-96 F series trucks. Specs on the stock motorcraft and the MSD look comparable. Plus...this will sound really stupid but I HATE the red color. I am searching the ole interwebs on what I need to do converting over to the TFI coil, but if anyone has advice, just wanting to avoid mistakes.
aquartlow ![]() Senior Member ![]() Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 2221 |
Andy,
If you hate the MSD red, tape off the terminals and paint the MSD distributor cap Ford blue engine paint-I found VHT paint works best(or whatever color you desire), I've been doing that for a while since using Accel dist caps(they have brass terminals)don't like the tan color
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2442 |
I wish you well with the ignition system, that seems to be an issue for most of the older cars. I never had trouble with mine in the 70's and 80's when I sold my 72. I have the Mallory system parts I bought when I was young and had my 72, but I never installed the Hyfire IV box, or the coil. I liked the Unilite distributor, but ages later people bashed them. I kept that too when I sold the car, I intend to put all of those on one of my 351C's. I'm watching with interest for more good news about what works these days.
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5846 |
maybe the 1st time i've heard it referred to as positive ground? what it does is the coil power flows through the tach, thus only 2 wires In & Out. the later 3 wire tach is similar to aftermarket tachs that use switched 12v power, a coil + signal wire and ground. i don't believe there is a way to use the Ford 2 wire tach with MSD? either swap out the 2 wire tach for a later 3 wire or get the 2 wire tach converted by a gauge outfit with an aftermarket make-it-happener
Greg73Oregon ![]() Senior Member ![]() Joined: 23-February-2021 Location: Roseville, CA Status: Offline Points: 222 |
This is an easy circuit to put together to supply full +12V to coil and ignition modules. The relay can be any general-purpose automotive relay (such as labeled "Ignition" or "Headlight", etc.).
GKF
