  New Posts New Posts RSS Feed - My 1970 Torino running choppy
Torino 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torino 70 Quote  Post ReplyReply Direct Link To This Post Topic: My 1970 Torino running choppy
    Posted: 01-June-2012 at 8:05AM
I have just replaced the spark plugs and wires in my 1970 torino and it now runs real choppy and the engine is shaking a lot when idleing, I tried to mess with the idle screw's, I think the air and fuel mixture is not right but when it reaches higher rpm's it does not shake but still sounds super choppy, what can i do to make it run smoother?
Torino Zach
Mark S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark S. Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2012 at 9:37AM
Hi:
Not to be disrespectful, but check if you might have altered the firing order when replacing plugs/wires. I've done it. If they're okay, try rerouting the spark plug wires away from each other. Sometimes they can leak current and cause a misfire in the adjacent cylinder.
Mark
1977 Ltd II "Eltee"
1984 Mustang ragtop
2004 Grand Marquis Ultimate Edition
71 Torino GT 429CJ (sold too many years ago to count...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2012 at 10:25AM
My thoughts exactly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torino 70 Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2012 at 9:27PM
alright thankyou, i have also boughht the sh*ttiest plugs but ill check the fireing order i might have mixed up 3 and 4
Torino Zach
This page was generated in 0.093 seconds.
