  New Posts New Posts RSS Feed - New Member - 71 Electrical issue !
Rayman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayman Quote  Post ReplyReply Direct Link To This Post Topic: New Member - 71 Electrical issue !
    Posted: 19-December-2009 at 2:21AM
Hey guys.  I hope this site is better than some of the others.  I have a 1971 Torino 500, 302 that is all original.  Aquired her last summer from the proverbial "little old lady".  One owner, Florida car that was garage kept.  103K original pampered miles.  Runs great.  I really can't say enought about how well this car has been perserved.  Anyway.
Started having issues with the car not cranking.  New battery.  New battery cables. New soloinoid between battery and voltage regulator.  New voltage regulator.  Would crank.  Run great. Then later would not crank.  So replaced all listed. Not getting current to engine.
It has the original fuesable links.  If I replce the wiring from ignitian to solinoid... what do I need to replace the fuseable link with.  Any ideas of amperage or fuse size?  Would an in-line fuse work best?  Any help would be great.
Now I have lost headlights, radio, etc.  Checked fuses...OK.  This is driving me mad!
stuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stuck Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2010 at 1:37PM
that car is way to clean for changing harnesses .at the back of the engine by trans dipstick should a ground cable to the firewall clean the connections. also get dielectric grease and apply it as you get a chance to all your plug connections / light bulb connections /and fastened connections. besides you having a simple ground problem your starter may not last long if original. your battery grounds with a large cable to the engine for the high amps of a starter the thin flat braided cable at back of engine grounds the body for lights/radio/heater motor/etc.
michigan
71wagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71wagon Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2011 at 2:56PM
FontI had the same problem  ran a #10 wire from engine to inner fender and no more problem.
while car is running check between ground lug on battery and body with volt meter  should read .05 or less
mine read 2 volts
71 Torino Wagon
Central Florida
