Oil filters |
Turbo301
Senior Member Joined: 11-March-2007 Location: London, Ontario Status: Offline Points: 331 |
Posted: 21-October-2010 at 3:20AM |
What brands to people recommend, and what are the part numbers of those brands, for oil filters for my '77 Cougar with the 302? I don't think I need anything really super expensive or fancy - it is an ancient, bullet-proof 302, after all!
1977 Cougar XR7
1980 turbo Trans Am 2009 Pontiac G8 GT |
Regul8r
Wix or Fram, thats what I use.
no issues
Turbo301
I'd heard that the NAPA Gold series were very good; any experience with those?
1977 Cougar XR7
Psquare75
No Fram. I'd flush out an old filter before using Fram, and I'm not kidding.
Mobil 1, Motorcraft, STP, Wix, are all good pieces. For your car I'd get the typical FL-1A and be done with it.
Regul8r
I've used them as well.
I have not had any issues related to filters in all my years.
Fram is available everywhere, with the Black Grip painting stuff on it... makes it easy to turn on and off by hand without slippage or using a filter wrench.
I think they are the Fram Extra Guard filters.
GranTorinoSport
Napa Gold are a Wix filter. That is what I use exclusively, except on the Honda for which I use Honda filters (usually I get the Japanese ones which are probably the best).
Wix has been a quality leader in filters for many years. |
Webmaster |
GranTorinoSport
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
An old and very unofficial study, but it is good to show how much difference there really is in oil filters from brand to brand. |
Webmaster |
Psquare75
That study (and others) made me shy away from Fram.
Regul8r
well now that I see THAT study... I am thinking... STAY AWAY!
moose0211
Senior Member Joined: 23-September-2009 Location: Baltimore Status: Offline Points: 456 |
I am running Purolator right now. I am not sure how good it is, the Pep Boys guy recommended it LOL.
302ford
Member Joined: 24-February-2008 Location: vancouver Status: Offline Points: 178 |
I just usually use Wix/ Ford Racing FL-1A
79 LTD II 408/TKO/3.7's
11.78 117.3mph. drag radials |
occupant
Senior Member Joined: 23-October-2006 Location: Lawton, OK Status: Offline Points: 1973 |
I have a FRAM filter in my trunk. I would never drive with it on though...intend to use it for an engine flush experiment shortly. Gonna run her nice 'n' hot, bring it home, drain the oil overnight, slap the FRAM on there, put a couple quarts of VR1 50-weight and a couple quarts of diesel in it, idle it for about ten minutes, then let THAT mess drain overnight. Then I'll put in 15W40 and the FL-1A I have sitting on my desk. Might get rid of some crud.
08 Explorer EB, 195K, for the wife still looking for another something |
Turbo301
I ended up just getting a Motomaster filter (Canadian Tire brand). The car hardly gets any mileage put on it a year anyway, and I have a feeling the motor is beyond what a good filter could do to save it LOL! Nah, she's a good motor, just tired and gutless. The previous owners of my car were not very nice to it, and the oil in it when I got it was black. The oil that I drained out of it this time, after 2000 miles, was gross, too - worse than the 8000 mile oil from my Pontiac G8, and kind of smelled like gasoline. Yummy! I'll be interested to see how my new oil fares come next driving season. |
1977 Cougar XR7
Turbo301
Interesting study! I'm surprised they'd recommend silicone seals, though: silicone has poor mechanical strength for a dynamic seal, and it is not compatible with petroleum products like nitrile is.
1977 Cougar XR7
Psquare75
Bad fuel pump?
Turbo301
Don't think so; why would that make the oil smell like gas? Can the pump cause gas to leak into the crankcase?
1977 Cougar XR7
Psquare75
Yup. Diaphragms break all the time in mech pumps causing fuel to leak into the crankcase.
Turbo301
Wow, I didn't know there was any connection between the crankcase and the mechanical pump. I'd never really stopped to think about it because I've never serviced a fuel pump. Huh. Could poor fuel delivery be responsible for my sluggish performance, too (or is that just a consequence of having a 360 hp daily driver )? |
1977 Cougar XR7
Psquare75
Turbo301, This is my Cougar with a stock 351W and 3.5:1 rear gears. your 302 should be a bit slower than this.
73 GT Sport 429
Senior Member Joined: 25-October-2010 Location: TarponSpringsFL Status: Offline Points: 277 |
Unless your engine is very slugged up, I would not recommend trying to flush it. In the eighties a customer had me add a quart of motor flush to his engine (followed directions on the can) before changing his oil. He later told me his engine failed within a month. Also today's oils do not contain zinc, a necessary additive for flat tappet (lifter) cams. I would recommend an additive with ZDDP (zinc) at every oil change! |
Mark
original owner-93 Lightning 73 Gran Torino Sport 429 (prodigal son) |
stuck
Senior Member Joined: 23-December-2007 Location: michigan Status: Offline Points: 279 |
fram paid me for a new engine . motorcraft daily driver k&n racing
michigan
Turbo301
Did Fram actually pay for a new engine due to a filter failure? I'd love to hear about that! I would have thought they'd do whatever it took to get out of such a warranty claim! |
1977 Cougar XR7
stuck
it was a new 440 about 1-2 years 10,000 miles or less .at the time it was $ 1800 to have it rebuilt [the estimate i got to offer them ] or pay me now $1400 .at 17 years old in the 80's i went back and forth with there claim rep .i said yes you will and he saying no we wont for what seemed like a hour [about 20 minutes ] i never gave in he never hung up and if it wasnt him trying to pay less than $1400 which $400 less than a new engine i may still have more respect for them .f cheaters. oh yeah they did investigate .
Edited by stuck - 26-January-2011 at 6:39PM |
michigan
GranTorinoSport
That is the first time I've ever heard of a flimsy warranty actually paying up on a real claim! That is very cool. I'm sure nowadays the warranty sharks are even better. That's why most times, I ignore warranties. It seems like things not worth trying to cash in on because of all the red tape they purposely put in. I always buy the best parts (that have the best warranties), but figure I'm paying for a quality part, not a warranty that will actually do something for me in years ahead. |
Webmaster |
