  New Posts New Posts RSS Feed - oil pan
oil pan
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: oil pan
    Posted: 30-August-2011 at 3:14PM
what is the difference between a mustang 2 and a reg 302 oil pan.I want to lower my motor in the pinto but the sway bar is in the way.Told I need a mustang oil pan?
ghosttrain2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghosttrain2 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2011 at 4:50AM
The difference will be whether it is a front sump, or rear sump.Mustang 2 and fox body Mustangs used a rear sump. 1973 and older were front sump.
1977 LTD, 2 door
1972 N code Ranchero, Project
1972 Torino formal roof
1970 Torino 500, Project
1974 Cougar parts car
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2011 at 6:36AM
would a mustang be smaller than reg. Mine is a front sump,large deep part in front.
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2011 at 9:51AM
fox body have double hump pan with two drain plugs.large in rear small in front,believe the pumps to be the same,but pickup are different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2011 at 11:28AM
ya double was on full size also. Mine is just large in front. thanks for the input
bob
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2011 at 4:36AM
mustang II is a front sump.
This page was generated in 0.061 seconds.
