  New Posts New Posts RSS Feed - Oil pressure light and gauge 351C
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Topic: Oil pressure light and gauge 351C
    Posted: 08-August-2014 at 1:42PM
Has anyone wired their Cleveland for standard oil pressure light and electric aftermarket oil gauge? and if you did, what set up did you use for the oil pressure port in the block?
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2014 at 2:00PM
Hey John. I owe you a phone call. Anyway I plumbed both senders on the back of the block using some brass fittings. They work fine and no clearance issues.
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2014 at 2:29PM
just a short 1/8" NPT pipe nipple & a Tee will do the trick, Brass is nice
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2014 at 4:32AM
X2
This page was generated in 0.081 seconds.
