  New Posts New Posts RSS Feed - Oil Pressure Sender
Oil Pressure Sender
Kiwi Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Dean Quote  Post ReplyReply Direct Link To This Post Topic: Oil Pressure Sender
    Posted: 27-June-2012 at 1:17PM
Hi there, I am wanting to get the factory gauges working in my '76 GT Ranchero as someone has fitted after market items.Can anyone tell me the correct part number for a new oil pressure sender and water temp sender. Also can anyone tell me the color of the wire from the oil sender.Engine is factory 400
Cheers Dean
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2012 at 2:52AM
If it is like the 77-79s 351 the ones sold in napa or ebay will not fit. They are 1/16 1/8 to large I found one in an after market kit for 65$ .I went with a mac one mounted on the ash tray. Only problem is memory loss. I forgot I had done that and when I started her this spring I was all upset when I had no oil pressure.Ha Ha on me
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2012 at 4:11PM
Did some searching as I need one also and found the real thing. The aftermarket ones are 0-80 or 0-100 PSI and I think for it to be accurate Motorcrafts is a 0-90psi sender.  I ran the search for my Cougar but these are the same for others also with the sport dash.
$21.35 they have 5 left in stock after I just ordered mine.
http://www.partsgeek.com/catalog/1977/mercury/cougar/body_electrical/oil_pressure_sender.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Dean Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2012 at 12:21PM
Thanks for that,can you also tell me what color wire I should be looking for as I can't seem to find a spare wire around the area where the sender is located. Whoever fitted the mechanical aftermarket guage might have cut the wire out??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2012 at 12:28PM
White with a red stripe. Connects back near the power brake booster along with the tach and coil 12 volt power. Sender is located right behind the intake on the engine block top where the transmission bolts up.
Edited by Robbdtme - 01-July-2012 at 12:30PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Dean Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2012 at 5:15PM
Ok got it,cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Dean Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2012 at 5:18PM
I found rockauto.com also has a few listed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2012 at 5:43PM
Awesome. Keep in touch Kiwi Dean
