Paint selection |
Post Reply
| Author | |
swampbug
Joined: 19-August-2015 Location: South Carolina Status: Offline Points: 130 |
Quote Reply
Topic: Paint selectionPosted: 10-September-2015 at 3:51AM |
I'm going to practice painting on my truck before I attempt a resto paint job. Is this enough to paint the truck?
Or will it take more? I still need to pick a primer and a clear as well.
kychevyguy
Joined: 16-December-2013 Location: Lexington KY Status: Offline Points: 1996 |
Quote Reply
Posted: 10-September-2015 at 6:04AM |
How big is the truck? I painted a full size truck (regular cab, long bed) with three coats using one gallon with a little left over for future touch up. But I did not paint inside the bed as I was spraying bedliner in there.
JT, USAF Ret./Architect
swampbug
Quote Reply
Posted: 10-September-2015 at 6:07AM |
My truck is a 92 Dakota(reg cab/bed), I will also be doing liner in the bed. If you did a full size with 1 gal, I should be good on mine then. Just need a gallon of primer and maybe a quart of clear?
kychevyguy
Quote Reply
Posted: 10-September-2015 at 6:20AM |
I typically get the same amount of clear as paint, but I like to usually do minimum of four coats of clear. I've always been nervous about cutting through the clear. I've done it a few times and you have to stop and re-shoot more clear back on, essentially taking several steps backwards. I'm a lazy painter and only want to do the sanding/cutting/buffing/polishing once. It's easier to take more clear for shine, but once you break through to the paint...It's like getting your hair cut, it's easier to keep going shorter while sitting in the barber's chair. But once they cut it too short, they can't glue it back on.
swampbug
Quote Reply
Posted: 10-September-2015 at 6:45AM |
What is the difference between primer and epoxy primer? And I was looking at something like por-15 to paint the frame with.
Post Reply
| Tweet |
