  New Posts New Posts RSS Feed - painting magnum rims
oldgold69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldgold69 Quote  Post ReplyReply Direct Link To This Post Topic: painting magnum rims
    Posted: 22-July-2020 at 6:00AM
I know this is a simple answer  but are the painted gloss or flat black  or do you paint it gloss then try and get it to flatten a little       thanks for any help   then there is another question on the quarter panel seam  the car had plastic filler in the seam  it was a vinyl top car rust lifted the filler out of the seam  I was thinking if I welded the seam shut  prime it and then put a metal patch in the seam then skim coat it with filler  do you think it would crack at the seam  I thought if I closed the seam it wouldn't rust  it is heavily pitted now  the rest of the roof just surface rust     thanks jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2020 at 1:22PM
IDK i think the wheels were semi-gloss?? if spaying it with a gun... you could add some flattening agent to the gloss paint then spray...
 weld the seam solid then use duraglas filler not regular filler! yes you can weld a patch in flush to cover the seamWink
USC Duraglas Fiberglass Body Auto Body Filler Quart - 24035
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldgold69 Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2020 at 3:38PM
thanks for the reply that help with the rims  the seam would be filled with about a half an inch of filler I just thought that would be too thick and would shrink in time  I would put in     in thin layers  and let it set good but if i fill the seam with metal it shouldn't shrink as bad  it will be a painted roof  thanks jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2020 at 3:43PM
ok if it's that deep, I'd trim a piece of sheet metal to fit over the whole seam flush, welded and ground smooth then body filler to blend it all perfectWink
