PCV Valve connection |
Damo70
Member Joined: 13-April-2010 Location: Melbourne Status: Offline Points: 76 |
Posted: 25-October-2010 at 12:49AM |
I was wondering whether some one could help me. I have changed my intake manifold to an edelbrock streetmaster 4V along with a holley 600 carby. I now do not know however were the PCV valve connects after to? The motor is a 351w on a 75 Gran Torino.
Finally the charcoal pot has 2 connections on it. There is a pipe from the air intake which I have however the second port sticking up leads no were. Does any one know what it should connect to?
Cheers
Damian
Psquare75
Does the holley have a large vacuum port at the base in the rear? or the front?
PCV goes there. The charcoal box on these usually has two ports.. a large 1" diameter paper hose (!) that goes to the air intake, and a small rubber hose that goes to the hard fuel tank vent line, which should be near the charcoal box on the frame. |
Damo70
There is no PVVon the carby. I will need to buy a 4 barrel plate which has the connection or upgrade carb. It is a case of getting a new carb with everything ready to go or get this one rebuilt. I think I will get a new holley 600. Thanks again
