Pertronix Ignitor mod. |
Rivercrest
Member Joined: 07-December-2019 Location: Manitoba Canada Status: Offline Points: 175 |
Posted: 10-October-2020 at 3:05PM |
So I just took out my points and installed the solid state 1281 electronic ignition. Following all the instructions, including the gap setting of .030 all is well.....except I now get a much lower dwell reading on my meter. Does a variation in the gap affect the dwell reading or is there really a dwell reading at all. Any advice is always appreciated.
Bob
1974 Cougar XR7 with a 72 351C |
the air gap should not affect your measured dwell reading, it's just an air gap specification to ensure that the reluctor and stator are close enough to communicate but not too close to contact each other. does your coil fall within the recommended ohm resistance ratings? how much lower, what's the dwell reading at idle and did you check to see if it changes with rpm? it possible the module uses a floating dwell depending upon spark demand, i'd call the tech line and see what they're willing or able to share
Edited by Rockatansky - 11-October-2020 at 7:56AM |
Rivercrest
My concern was dwell with points was 27 (within factory specs) and now it measures at 21 . Reality is the engine runs the same before and after the swap so I really have no concerns, perhaps the electronic points don't give a true reading that my dwell meter can follow. I'll call the tech line and report back...
Bob
i don't think you can get a needed dwell reading with electronic, it was mainly for the points for coil saturation. .030 gap for the pick up to stator??? i don't think it needs that kind of gap!
Rivercrest
As a follow up, I spoke with the Tech support team, dwell is electronically fixed and as mentioned earlier the gap is not critical but .030 is a good number. As a side note, because I have an resistance ( ballast ) component to run my factory tach and I could not easily find the "before ballast " connection so I installed a sensitive 12 volt relay at the coil positive and wired the contacts to supply 12 volts to the Ignitor module fed from the positive battery post. Seems to work well so far....
Bob
I did the same with when I ran a 1281 Pertronix module. They often will run off 8 volts or so, but 12 volts is better. Make sure the 12 volts from the relay is fused.
Rivercrest
It is fused at 15 A with an extra fuse in the glove box for when I need it LOL
Bob
BadHabit351
Senior Member Joined: 21-June-2013 Location: United States Status: Offline Points: 217 |
Put your points & condensor in there with it...based on my experience with a pertronix unit. I went through 2 replacements & my brother in-law is on his 2nd with his 69 Bronco. On the other hand, our other buddy has the same one in his 72 Mustang Mach 1 for over 10 years. All of them installed the exact same way.
1973/72 Gran Torino Sport
1971 Torino GT convertilble 2013 Ford Fusion 2004 Ford SuperDuty 2013 Mustang GT |
Lizer
Member Joined: 04-January-2020 Location: SW Michigan Status: Offline Points: 70 |
My Pertronix Ignitor II has been in my Mustang for 5 years now with no issues, knock on rust.
67 Mustang (5.0) 69 Mach 1 428 SCJ Drag Pack |
J Moore
New Member Joined: 18-October-2020 Location: Washington NC Status: Offline Points: 36 |
Thanks(1)
Hi I am new to this forum and a little late on this thread, but I thought I would share some Petronix experience with all. First, 1973 Ford F250 with 390 wouldn't hardly run when cold. After engine got to temp and after heat soaking after shut down it would run fine. Long story short.. I found the Ignitor module rubbing on the trigger wheel. Research promoted me to set .030 clearance between the two. Problem solved. Second...72 GTS Q had major issues with ignition. It came to me with Petronix Ignitor I series. The gap was fine. Longer story short...too much resistance in ground circuit. Petronix chief engineer says NO More than .2 ohms. I measured 8 ohms in circuit. Module needs FULL 12 volts to function correctly. Not 10 or 8 or anything less than 12. It was wired to coil feed which is resistance wire for run circuit. (A spliced in harness connection provides 12 volts when starting). I connected the module feed wire to the idle solenoid circuit which has full 12 volts in the run position. I cleaned every ground connection point from the distributor to block, block negative cable connection point, battery negative post connection, and even the engine to body ground connections. Then measured 0 ohms resistance from module mounting bracket on point plate to Battery negative POST. Problem solved. I am going to post a link to some Petronix tech info that gets in depth with the voltage and grounding issues. HTH someone. John https://vintageperformance.com/retrorockets/low_voltage.htm
Edited by J Moore - 20-October-2020 at 3:48PM |
Rivercrest
Thanks for all that info, electronics are great when they work. a pain when they quit without much warning. PS: I can't seem to get a response from your link.
Bob
J Moore
I don't know why link doesn't work. It copied verbatim. Oh well. John
gpd294
Senior Member Joined: 18-September-2008 Location: Dallas, Texas Status: Offline Points: 2178 |
It's weird when you google that link it takes you to the web page options, but the link itself won't work...
