  New Posts New Posts RSS Feed - Ping at cruise speed
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2024 at 12:30PM
Originally posted by Inkara1 Inkara1 wrote:
On the new crank or the old one?
the new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2024 at 9:36AM
Thrust surface:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-March-2024 at 3:36AM
that's what i was afraid of, i might've passed on this crank, may be a core or an unfinished reman in progress?
IMO it needs to be seen by the nearest crank doctor for evaluation, that thrust surface looks like Joe chowdered on it with his sawzall.
i don't see how it's even measurable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:28PM
So I finally got some space in the garage cleared and all the accessories removed from the engine. I have the a/c compressor suspended from a wood board with some tie wire so I don't have to unhook the likes and, er, properly evacuate the refrigerant. I hope to unhook the transmission and exhaust pipes tonight and pull the engine tomorrow morning.
One question for when I complete the work and put the engine back together:
I bought a water pump for it a couple of years ago, but the pump that was on it was good, turns well, is quiet, and doesn't leak, so I left it alone. Those properties still apply. But given what a pain it is to get to the pump, and also given the spotty quality of replacement parts, would I be best advised to stick with the current pump or put on the new one? The brand of the new pump is "Airtex."
78FordLtd2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 78FordLtd2 Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 13 minutes ago at 7:26AM
When I replaced my timing chain on my LTD ll, the old water pump, like yours, was still in good serviceable condition. I put on a new water pump anyway but kept the original. It seemed like a good idea at the time as everything was already apart. The choice is yours but I'd swap it out anyways.
