  New Posts New Posts RSS Feed - Piston rings
Piston rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Topic: Piston rings
    Posted: 18-April-2015 at 6:41PM
Total Seal Claimer Piston Rings CL9090 30
The cylinder heads have checked out the machinist is read to go with the Cleveland. I'm gathering the parts and he was specific on a couple of items. One of which was the above listed ring set.
Apparently he's not a fan of chrome moly in general or for this specific project, I don't know yet. I'm doing research as I go a long and have come across pros and cons of gapless rings (excessive oil consumption being a major con). These apparently have a gapless second ring. From what I've gathered so far they recommend restricting the PVC (?).
I've got parts coming that should keep him busy for a minute. In the mean time..........anyone have any input on this particular selection?
13 Taurus SHO "Mr Pig"
Nomadlife View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nomadlife Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2015 at 1:28AM
From the page I reference in my post
"Piston rings are a subject of rapid technological development fueled by the auto manufacturer’s pursuit of better fuel economy and lower emissions. It’s an area that you should spend some time researching and getting advice before you make a purchase. Piston ring thickness and tension creates friction that resists crankshaft rotation. Decreasing piston ring thickness or tension reduces the energy required to keep the crankshaft rotating, and therefore increases the power available at the rear wheels. The additional cost of high-tech rings over the price of standard cast iron rings constitutes one of the least expensive ways to increase horsepower. Modern thinner or lower tension piston ring sets can offer higher output at the rear wheels and better durability with no penalty in the life of the rings. A good quality OEM thickness 5/64” plasma moly ring set using a barrel faced ductile iron top ring will cost about $100 to $120. A top-of-the-line "thin" 1/16” chromium nitride faced ring set using a steel top ring will cost $280 to $380. So improving the technology of the piston rings will cost $280 or less. That's some relatively inexpensive horsepower. The Ross pistons I recommend are designed for the thinner 1/16" rings"
Marilyn - '72 Ranchero 500 - known her since I was born, and traveled across the states in her; first in the back, then as the driver. Under restoration (and a little modification)
James
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2015 at 6:21AM
That's what I love about this site. Thanks much.
