  New Posts New Posts RSS Feed - Police Handling Package on 73 Torino
jester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Topic: Police Handling Package on 73 Torino
    Posted: 27-September-2015 at 6:00AM
Hey!  I have a 73 Gran Torino Sport Fastback (Q Code), which came with a factory rear sway bar.  I understand that the existence of the factory rear sway bar indicates the car was ordered with the Police Handling Package.  My question relates to the brake system which may have come with the Police Handling Package.  What size rotors came on a car so ordered?  Does the rear sway bar specify a package which comes with the Police Brakes?  Aftermarket stores, like AutoZone, show the difference in rotor size between standard disc brake rotors and police brake rotors as 10.75" vs. 11.75", respectively.  My car has the factory 14" Magnum 500 wheels.  But research states that the 11.75" rotors require a minimum 15" wheel.  Is my research lacking or will the factory Magnum 500 work with the police brakes?  What gives?  I ask because I want to upgrade my rear drums to 98 Explorer rear disc brakes, which have a 11.2" rotor.  Will my 14" wheel fit the 11.2" rotor?  Thanks!
tonym9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonym9 Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2015 at 2:34PM
IIRC Q code 72 and 73 FB's came with a rear sway bar, police pkg isn't determining fact for sway bar.
IIRC the lincoln or 'big' ford bodies had 12" front discs and 'intermediates' (Torino) came with 11" fronts.
IIRC rear drum 72 and under was 10 or 10.5??? inch, 73 up are 11 inch...both will wear 14" rims. I don't think the .2 will cause a problem but I'd test fit as much as possible before doing the swap.
Please correct me guys, info is from memory...don't want to steer a new member the wrong way
72 GTSFB
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2015 at 3:23PM
I have a 72 Q code and it didn't have any special handling package. Ir didn't have a rear sway bar and had a skinny front bar. I think the handling package was an optional thing.
-Billy Conturo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2015 at 3:45PM
my 72 Q code had front & rear bars, definitely not PI
wheel fitment will need to be checked with the specific components, it's possible that one type /style of steel wheel will fit where another may not due to the particular forming of the drop channel of the outer rim
it's not just the rotor diameter but the caliper above & beyond the rotor that will cause the fitment issue
Edited by Rockatansky - 29-September-2015 at 3:47PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 12:03AM
Thanks for the info, Guys!
I crawled under the Torino to measure the existing rotors as best as possible.  The rotors appear to be the nominal 11".  I think they are called 11", even though research seems to indicate their actual outside diameter as 10.72".  This is the measurement specified by all national big name auto parts stores like Advance Auto, AutoZone, O'Reilly's, etc.  Note:  NAPA gives different sizes for most all measurements.  As for the other stores, for the police/taxi rotors, which you nominally call 12", the actual outside diameter is 11.72" (Same indicated for the 76 77 Lincoln Mark IV, etc.).  Some websites did specify a 11.78" or 11.79", but most called them 11.72".  Maybe measurement depends upon who is doing the measuring.
I, also, researched the 72 Thunderbird (Small spindle & rotor 11.72" with 5 on 4.5), 72 73 Torino (Small spindle & rotor for police/taxi 11.72 with 5 on 4.5) and the 74 Torino (Large spindle & rotor for Police/Taxi 11.72 with 5 on 5 ****NOTE the 5 on 5) for, both standard and police/taxi rotors and bearings sizes for the different rotors.  As previously stated here within this forum topic, there is a big different between bearing sizes for the 72 73 Torino and the 74 Torino (Both standard spindle and police/taxi spindle).  The outer bearings on both spindles appear to be the same.  It is the 'inner' bearing which is smaller on the 72 73, whereas larger on the 74.  As stated before, the 74 Torino wears the same spindle bearing sizes as the big cars.
NOTE:  I forgot to research the 'height' dimension for the different rotors.  I assumed all these would be the same, since many of you indicate a straight swap of big rotors (Front & Rear) off large Ford & Lincoln cars is possible on the 73 Torino, if the Torino has the large spindles and with swapping axles from 5 on 4.5 to 5 on 5.
Also, as stated, in order for me to be able to determine whether or not I have the early small spindles or the later larger spindles mounted upon my particular (Late February build or mid year if 73 nominal build begins in August) Torino, I'd have to pull a rotor and check bearing part numbers.
NOTE:  Research indicates the backing plates for the nominal 11" and the nominal 12" brake rotors are the same.  Thus, no need to change those.  The 12" will fit the 11" backing plates.  The rotor just fills out the backing plate fully, but with no overhang.
ALSO, I researched to find Magnum 500 wheels for the 5 on 5 bolt pattern.  There aren't any...  Not made...  Cannot be ordered.  Thus, if I wish to upgrade to 5 on 5, then I cannot upgrade to 15" Magnum 500 wheels.  This would be important to me, since I would wish to keep my Torino appearing (At least from the outside) to be factory built.
The aftermarket makes great stuff!  You can greatly enhance your old muscle car using technically advanced components.  However, when you begin to put modern components on your old car to make it faster, handle better, etc., then you end up with a resto mod.  And collectors don't like resto mods.
That said, if you already have a rare high performance car from the factory, changing to modern components means you can FORGET about what price you can sell your car to a collector for.  Ain't happening.  He'll take one look and walk away.  And remember, value for original cars goes up, not down.
Well, our Torino cars do seem to be somewhat lagging in value considering other cars (Mustangs, Chevelles, GTX's, Chargers, Camaros, etc.).  But a factory muscle car is still a muscle car.  And for 72 73 'Q' Code Torino owners, we have a muscle car...  Even if it has a C6 transmission.  Although those 4 speed 72 73 cars do seem to get much more attention.
Edited by jester - 30-September-2015 at 12:51AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 12:34AM
From research thus far, if I have the smaller spindles, all I need for a swap to police/taxi rotors are the rotors off a 72 Thunderbird (Good luck finding them) and the mounting bracket off the same or any other large 70 to 77 Ford or Lincoln car.  Backing plates DO NOT have to be changed.
NOTE:  This upgrade would demand that I upgrade my Factory 14" Magnum 500 wheels to 15" Magnum 500 wheels AND tires.  This is do-able, if I have money to blow.
If I have the large spindles, then I must install the 12" nominal rotors with the 5 on 5 bolt pattern and, either, forget about Magnum 500 wheels or re-drill the rotors to a 5 on 4.5.  Backing plates remain the same as currently on the Torino.  Mounting brackets still must come off a large car.  Well, I still need the 15" wheels and tires, as well.  This is do-able if I have even more money to blow.
For a swap to rear disc brakes, this appears to be a much easier swap.  I can take the complete assembly off a circa 1998 Ford Explorer, which has 11.2" rotors, built in emergency brake mechanism AND a 5 on 4.5 bolt pattern.  This, I'm told, is a direct fit system.  Again, even with the 11.2" rotors, it is advised to change wheel size to 15".  This swap to front & rear disc brakes demands a master cylinder change.  I must purchase a master cylinder for a Ford or Lincoln car, which came with front & rear disc brakes.  This does not seem to be an overly expensive swap, except for the swap to 15" wheels & tires.
NOTE:  The ideal swap would be if my spindles are the early version and IF I could locate the rotors for the 72 Thunderbird.  Still need the larger mounting brackets for the calipers.  Then, add the complete rear disc brake system off the 98 Explorer and the master cylinder off a 76 77 car, which came with disc brakes all around.
The most expensive part of the swap is the expense of buying 15" wheels and tires at around $1,300.00 to $1,600.00 a pop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 3:36AM
The Competition Suspension was available as an option on all Torinos except the wagons in '72. It had better shocks, revised rear suspension arms, rear bar, stiffer springs, larger front bar. It was not standard on any version GTS or otherwise regardless of the engine. To add confusion, there was a more comprehensive option that included the Competition suspension and Sport cluster all in one package. It was also available on non-GTS cars and 4 doors. The Sport cluster package was available as an option on all Torinos including wagons. Front brakes were the same across the board, but larger rear drum setups could be ordered.
The Police Package had different springs, the better shocks, larger rotor and drum sizes, 5 X 5 bolt pattern, revised suspension components, rear bar, larger front bar, HD battery, HD cooling, transmission cooler, 15 inch steel wheels, rubber mat and was almost exclusively on base Torino 4 doors only. However, Ford was famous for allowing ala carte ordering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 4:11AM
Explorer disc swaps are very nice, but keep in mind that the front brakes do 75% of the stopping, so fronts need the most help. I have several Explorer and CVPI disc setups in my garage waiting to install on my cars. The CVPI setup has larger rotors, but a shim must be inserted when installing. I'm using the Explorer setups on my Coupes and the CVPI setups on my wagons due to the weight. I'm also adapting the master cylinder and proportioning valves to compensate for the added rear stopping power.
Pictures of one of the Explorer setups:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 4:52AM
Great info, Joe!
It is interesting that the 72 73 Torino with police/taxi rotors had the 5 on 5, as well.  Thus, a swap to the 72 Thunderbird 12" would not be correct for the 72 73 cars.  The police package certainly came with everything upgraded.  If the package came with rubber floor mats, maybe that would cause most buyers, even when ordering their cars, from ordering the police package.  But maybe ordering the bucket seat interior, which came with special floor mats which had rubber inserts inside the carpet material, would have superseded the plain rubber floor mats.
Wow!  That would be something to find.  It would be as hard to find as a 72 73 with the extra heavy duty transmission and rear end package.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 5:24AM
If your '73 has the small bearing housing, the CV rear disc conversion is an easy swap, if it has the later model ("should" have) "Torino" wheel bearing housing, then from what I have heard and/or read the Explorer rear disc conversion is a more direct install. I used a CV rear conversion on my small bearing housing out of a '72 Lincoln Mark IV(9 3/8 w/ 31 spline axles):
Doing this conversion on a small bearing axle requires a spacer between the axle retainer plate and wheel bearing:
 and usually a hub pilot spacer due to differences between the axle pilot and rotor's pilot hole(the 9 3/8" 31 spline axles has the exact same pilot size that the rear CV rotors have, so no spacer required).
There are a few issues to be ironed out when doing the swap: A) E-brake cable linkage. B) Proportioning valve(an aftermarket GM based prop valve is almost a direct bolt-in due to the input/output port sizes) and it works quite well. C) A disc/disc master cylinder(a '75 or '76 T-bird or Mark IV or V will work fine). Hope this info and/or pics are helpful in some way. Good luck on upgrading your brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 7:35AM
Your car would not have the "Police Suspension" unless it was a police car.  The rear sway bar would indicate that you have the competition suspension.
Ford had three suspension options available in 1972-1973.  Base, Heavy-Duty, and Competition.  Standard had the softest springs, and smallest front only sway bar.  Heavy-duty had stiffer springs, bigger front bar, heavy duty shocks.  Competition included stiffer springs, heavy duty shocks, largest front bar, rear bar, heavy-duty upper control arms with stiffer/smaller bushings.  Only the competition suspension included the rear sway bar.  Police suspension was very close to the competition suspension but included solid front upper control arm bushings and rear springs with a higher load rating (ie designed to carry more weight).  The front springs on the completion and police spec cars were identical in spring rate, but the police spec springs were sometimes taller.  Police/Taxi cars that used the 250 or 302 used lighter duty suspensions which were basically the same as civilian cars with heavy duty suspension (note the Taxi option was ONLY available with 250 or 302).  The Police cars with 351 and larger engines used the suspension that was comparable to the competition suspension cars.
A few clarifying points.  The Competition suspension was only available in 2-doors with the 351-4V (Q-code) or the 429-4V (N-code).   As stated this was not standard on an GTS.  The suspension was included with the Rallye-Equipment option package, but again this was only available on 2-doors with the 351-4V or 429-4V.  The instrumentation group (gauge package) was not standard on a GTS either, and was available on any car with a V8 except for those with the Brougham interior cars.  The police package on the other hand was available on the 4-door and 2-door cars. Police spec cars also got an exclusive 429 "P-code" option, that did not have a horsepower rating by Ford.  But by looking at the specs, I bet it was easily the most powerful engine for 1972 (too bad it wasn't offered in civilian cars).
Police spec cars used the larger 12" (11.72") rotors and also include 15" wheels.  For 1972 the Police cars used 5 x 4.5" bolt pattern, the same as the 1972 T-Bird and Mark IV.  It also shares the rotors with these cars.  In 1973, these rotors were change to 5 x 5" bolt pattern for the Police cars and the T-bird/Mark IV.  Most people who upgrade to the 12" rotors try to find 1972 Police/T-bird rotors to keep the same bolt pattern, but they are hard to find and expensive.  Another option is to have 5 x 5" rotors re drilled.  Here is a threads with more detail:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 9:29AM
In my car's history, my car had me puzzled.
In the car when i got it, the 2nd owner handed me a heavy box, which had used rotors and caliper brackets. Along with another big box with the factory console in it.
Anyways, when I contacted Ford customer service to run a history on my VIN, my car being a Q code 351c 4V 4 speed was optioned, per the breakdown with the rally package, the maximum handling package, and the competition suspension.
Now, in the box, I tossed it in the trunk and ignored it for years until I pulled out and notice the rotors were bigger than the 11" units on the car.
They measured out at the near 12" OD.
I was told the 12" rotors were original to my car along with the caliper brackets, but you have to run a 15" wheel to clear the larger rotor. The police/tbird rotor will not fit a 14" wheel due to the caliper bracket spacing out the caliper and that would hit on the bell area of a 14" wheel.
My car had 14" factory magnum 500's but once again the original buyer, the guy who originally bought the car lived a block away from the 2nd owner whom I purchased from.
I was told by the 2nd owner he pulled the rotors and swapped to easier to find 11" rotors in the early 80's due to being a college kid and the eternal argument of beer money vs car parts.
I've also swapped 1972 Mark V rotors on my spindles when i was test fitting my 15x11 Nascar wheels before I went to my 1999 crown vic brake modification.
Other notes:
If your factory rear sway bar needs bushings, I rebuilt my rear arm frame mounts due to rust, using a universal sway bar end link kit, and having 1970's CJ-5 engine bushings turned down to size by a machine shop. I didn't replace the bushings at the end of the bar as they were still in good shape.
Correct me if I am wrong, but don't the later 70's police cars use a 1-1/8" rear sway bar?
Also, the engine specs for the police 429 and 460 cars were built to the same specs as a 1970 429 cobrajet...and were non-emissions setup with smog-delete.
One of guys, John, up in your neck of the Great White North and land of the McKinzie Brothers
happen to have a 1976 ex-mounty patrol car in Ontario I want to say and it puts out like 455 ft lbs of torque...at the wheels...{Eat it olds 455 guys!}
Anyways....that's my hear-say for the moment on this topic.
Edited by Eliteman76 - 30-September-2015 at 9:31AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 11:24AM
Hey aquartlow!
Thanks for the clear and very informative pictures.  I wondered where the spacer went.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 11:34AM
Hey Vince!
Great information and really ties down the change from 72 with 12" with 5 on 4.5 rotors to the 73 with the 12" and 5 on 5 rotors.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 11:41AM
Hey Andrew!
Happy for the hearsay.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 11:52AM
what I've seen in the listings on Rockauto & others is that the 1972 T-bird rotors ARE the Torino Police & Wagon rotors as well, not sure what they did for late 1973 but I would guess that's when the cop brakes went 5-5
1972>mid 73 - small spindles & 5-4.5 across the board
mid 1973 + - spindle upgrade &  for 5-5 Police & Wagon
hey, I could be wrong, can we find documentation?
edit: pretty much what Vince said I guess
Edited by Rockatansky - 30-September-2015 at 12:00PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2015 at 12:31PM
Hey aquartlow!
Jim
You are very welcome! You probably already know this........The spacer is there due to the thickness differences between the drum backing plate and the CV's backing plate. My spacer measured:
but I have heard where spacer thickness #'s varied, so careful measurements are required. There are some that just use a flat washer and cut a slot so wheel bearing removal isn't a necessity, but I wanted to install new wheel bearings at the same time I had the machine shop make the spacer on their lathe. Always glad to help if possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2015 at 8:36AM
That is really unusual that your car had 12" rotors from the factory.  The police spec option was not even available on a fastback cars, just formal roofs.  But as we all know, Ford did build some cars that didn't always follow the rules.  Did you ever get a Marti Report on your car?  Do you have the build sheet?  What wheels did it come with from the factory?
And I believe you are correct that later police cars had a 1 1/8" rear bar.  Would love to find one of those today....
The P-code 429 had similar specs to the CJ's but the big difference was that it had lower compression than the earlier engines.  But still considering that the 1973 460 PI was rated a 269 net hp, I think the 1972 P-code would have been in the same ball park.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 28-October-2015 at 11:07AM
I have a 73 Gran Torino with the factory rear sway bar.  I measured its diameter and got 11/16".  I'm trying to fully restore the suspension with new everything front & rear, i.e., springs, bushings, shocks, ball joints, etc.  Plus, I want to use all polyurethane, instead of rubber.  I'm having trouble finding the rear sway bar link kit.  The factory link kit came with the lower link attaching to the sway bar with a horizontal bolt through a horseshoe, which has rubber bushings.  The vertical link kit, which is normal to other sway bars won't work.  I can only use some universal bushings (I hope) with the factory link kit.  The upper link is vertical and seems to take universal bushings.  Is there an OEM link bushing kit for this rear sway bar, especially for the lower link?  I'll have the old hardware sandblasted and powder coated for re-use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-October-2015 at 12:54PM
here's the post for the urethane bushings i used:
joe, yes there was a "9"  my bad the part #'s are   energy suspension 9-8141 universal shock bushings (for sway bar)    energy suspension 9-8101 universal shock tower grommets (for sway bar  link to frame bracket)      for the sway bar mount on the differential i used prothane # 19-1116  Thumbs Up
energy suspension:
9-8141r (red)
9-8141g (black)
9-8101r (red)
9-8101g (black)
prothane:
19-1116 (red)
19-1116bl (black)
****note, you stated you have the larger 11/16" sway bar, so the prothane #'s listed above are for the smaller rear bar***
Edited by californiajohnny - 28-October-2015 at 12:58PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 28-October-2015 at 11:26PM
Hey John!  Thanks for the info.  I've added those parts to my Amazon cart.
Next question...  Are there supposed to be coil spring insulators, both, at the top of the springs and at the bottom, as well?  So far, I've only found two sets of insulators, one set for the front & another set for the rear springs.
Prothane offers a set of insulators for the front springs.  But I couldn't find the part number.  For my car, it appears the bottom of the rear springs do not have insulators.  Nothing has been disassembled yet.
I have not been able to have a better look with proper lighting.  And I don't have any way to get up under the car for a good inspection.  What I've seen was from when my mechanic installed a 7 quart oil pan.
The heavy duty front & rear coil springs have arrived, along with an Energy Suspension 4.3120G rear control arm bushing kit.  It comes with shells for the lower control arms.
The upper control arms are different from the control arms on my Mustang.  They are cast iron and attach quite differently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-October-2015 at 2:32AM
IIRC mine only had thin OEM insulators only on the top of the springs front and rear
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 29-October-2015 at 10:51PM
Mine was like John said... ONE TOP SIDE ONLY front & rear.
A word of advice on using the poly bushings.... COAT THE BUSHINGS WELL WITH THE POLYURETHANE LUBE BEFORE ANY ASSEMBLY! You'll be glad you did.... OuchBeer
Edited by TV 2M8O - 29-October-2015 at 10:57PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 29-October-2015 at 11:38PM
I just ordered extra super grease along with my latest Amazon order.  This order got the rear sway bar bushings suggested above, as well.  Also ordered were the coil spring insulators.
Yesterday, I received a large package of suspension parts from P-S-T for front & rear.
The underneath of my car is a mess.  It needs to be cleaned and parts of it should be sandblasted.  Finding a mechanic who can or will do that is not easy.  For any parts which will be re-used and will be coming off the car anyway, I have someone who will blast them and powder coat them.  That still leaves the rear differential, which looks bad.  The front end radiator support and framing are ugly, too.
I was given the name of a machine shop, which has a large sandblasting facility that might jack the car up and do the work.  But I need to go talk to them.  I'd guess that I would not want the entire underside of the car blasted, especially that part which came painted body color from the factory.  I'd guess I just need the frame work & differential blasted and painted.
I suppose I could rent equipment to do the sandblasting myself.  However, someone else would still need to remove the necessary parts, like dropping the differential.
And removing the old rubber bushings from shells so the shells can be re-used with Poly bushings doesn't look fun.
Edited by jester - 30-October-2015 at 12:11AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 30-October-2015 at 2:01AM
Removing the rubber from the shells is EASY PEASY...
The other frame areas you talked about can be done with a bucket blaster and the car a couple feet in the air but it's a dirty messy experience....
In the long run it's worth all your efforts!!
GOOD LUCK
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-October-2015 at 2:26AM
yep, joe's a grillin' fool, while other people are grilling burgers on memorial day, not joe he's grilling bushings!!! now that's a "true car guy" LOLLOLLOLLOL
Thumbs Up Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-October-2015 at 9:17AM
Great pictures of your resto!  From those, I can see details I had not imagined.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-October-2015 at 10:01AM
james, were you referring to my thread or joe's? anyway the LED's i have in my car and my kenworth are from these guys: they should be available at most big truck "chrome shops". but here's a link to their green led's for the dash (plus all other colors and lights)
Click on Image Enlarge Technical Diagram
 http://www.heavydutylighting.com/product_detail.php?uuid=aD55759E0A
Edited by californiajohnny - 30-October-2015 at 10:02AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jester Quote  Post ReplyReply Direct Link To This Post Posted: 30-October-2015 at 10:21AM
Hey John,
Yep!  My dash lights definitely need more light.  Thanks!
I went to Joe's website and looked at all his pictures.  There were so many I couldn't get through them all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-October-2015 at 11:17AM
well if it's pics you want to see-- here's my thread:
 http://forum.grantorinosport.org/johns-74-sh-clone-build-thread_topic10024.html
also you'll need to take your cluster apart and remove the blue globes where the lights go, they pop out pretty easy!
This page was generated in 0.142 seconds.
