  New Posts New Posts RSS Feed - POR15 wifemeter factor
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: POR15 wifemeter factor
    Posted: 16-February-2019 at 2:54AM
I have my front suspension all apart and am at the point of painting the parts but can't do it outside for quite a while due to weather.  I plan on brushing POR15 on and am curious on the smell/noxiousness of the fumes if I were to do this in the basement.  Are the smells something the wife will graciously accept or bad enough that the stare of death will be present for the forseeable future?  thanks  -  dave
Dave - 1973 GTS N code
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2019 at 5:07AM
All I know is if it's a zylon(sp) base paint it needs a lot of ventilation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2019 at 7:54AM
not sure on poe15 but the sem rustshield is strong fumes, but open a window after its painted and maybe a small fan too any fumes should air out fairly quickly...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2019 at 8:37AM
I haven't used it in many  years, but I know it is impossible to get off your hands.  Read the container and it should say if it needs to be in a well ventilated area.  I'd probably guess it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2019 at 11:28AM
Just don't get to the magic air/fuel ratio. Get the ventilation going before you start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2019 at 12:25PM
Well, that answers that question, I guess I will find another route to accomplish this.  thanks to all - dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2019 at 2:55AM
what vince said...  when i started painting my frame with POR15, i disregarded the warnings.  I walked around for three weeks with black all over my hands.  it is IMPOSSIBLE to remove from skin.  after that, i went and bought a box of latex gloves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2019 at 1:01PM
Stinks like hell, sticks to skin like a tattoo.
Sticks even better in your hair.
It will soak thru your clothes and fuse them to your skin. Especially socks.
You WILL say bad words.
