power steering question |
wagonwx
New Member Joined: 21-October-2022 Location: california Status: Offline Points: 6 |
Posted: 15-April-2023 at 4:03AM |
Replaced the power steering pump and control valve on my 70 Torino and now the steering has a life of its own. When I start the car the wheel moves violently back and forth once touched. only way to stop it is to turn off the engine. I think I may have gotten a bad control valve but not sure. Any suggestions?
72 RS 351
Be sure the air is completely out of the system, that can cause violent issues with the steering.
Greg73Oregon
Senior Member Joined: 23-February-2021 Location: Roseville, CA Status: Offline Points: 232 |
Yes! Be careful!
Try raising the front-end off the ground (jack stands) and chock the rear wheels. Start the car (be sure transmission is in Park), rotate the steering wheel all the way left and then all the way right a few times (or more). Re-check power steering fluid level. Add if necessary.
GKF
Agree with the others. Bleed it like Greg says and report back. I suspect there is air in the system.
i'll bet you have a line crossed, seen it before
if it goes lock to lock violently its a swapped line!!! 2 of the 4 are swapped! not a fan of that remote control valve system my vette has a system much like that one day it will get the direct borgson box conversion
