Print Page | Close Window
Converting standard diff to locker?
Forum Name: 1970-1971 Ford and Mercury
Forum Description: Technical discussion for 1970-1971 Ford and Mercury
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=1023
Printed Date: 26-March-2026 at 11:31AM
Topic: Converting standard diff to locker?
Posted By: rallye
Subject: Converting standard diff to locker?
Date Posted: 03-April-2007 at 9:27AM
I finally determined that my '70 Torino GT has a standard axle with a 3.00 ratio (thanks to MartiAutoWorks for generating my build sheet from a VIN).
Is there any way, short of swapping axles, to convert the axle into a locker?  Fitting new internals into the case?  Even if it requires substantial work, it will be cheaper for me to go the conversion route rather than swapping -- the car is currently in Poland with my father, and while labor is dirt cheap in Poland, shipping a few hundred pounds of car parts to Poland is not.
Thanks in advance for any tips or wisdom.  Even if it is to tell me that the only thing I can do is swap in a locker.
