Print Page | Close Window
torque converter
Forum Name: Small Block Forum
Forum Description: 221, 255, 260, 302 and 351W engines
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=11053
Topic: torque converter
Posted By: mkshelton
Subject: torque converter
Date Posted: 18-June-2014 at 8:36AM
So, it'been a while but I just got the 351 w back from the shop and I'm thinking about the torque convertor. The motor is now at 8.5 compression stock crank, 4 barrel with headers and dual exhaust. Ported stock heads. Any suggestions?
Posted By: antlerfiend
Date Posted: 18-June-2014 at 10:53AM
What is the power band of the cam?
Date Posted: 18-June-2014 at 3:05PM
It's an edelbrock claims from idle to 4000 rpm.
Posted By: Rockatansky
Date Posted: 18-June-2014 at 4:15PM
I'd drive it with the stock converter first, if it 'leaves like a bus', maybe a 2000 stall
but an idle >4k cam probably won't need a converter
Date Posted: 18-June-2014 at 5:01PM
I couldn't agree more.
Date Posted: 19-June-2014 at 5:26PM
Thanks guys, that's what I was thinking, just wanted to confirm.
Date Posted: 20-June-2014 at 10:27AM
do you have the 2172 cam?
what do you have for a rear gear in it?
Date Posted: 20-June-2014 at 1:57PM
The 2182 actually.
Date Posted: 21-June-2014 at 6:46AM
Ohhhh...
I always default to 351C Wacko
http://www.edelbrock.com/automotive/mc/camshafts/locator.php?part_number=2182&submit=go" rel="nofollow - http://www.edelbrock.com/automotive/mc/camshafts/locator.php?part_number=2182&submit=go
2.75 / 3.00 you may not be a tire fryer off the line, 3.25 / 3.50 will add some snap at the expense of fuel economy
