yup I set the heat shield into a 'sandwich' of RTV, it just kinda floated below the intake, the ends I made sure were trimmed inboard enough to have good silicone in the corners kinda depends how I feel at the time, what my expectations are for the install. High Tack is pretty darn permanent, definately a good choice for a customer car or an engine you don't plan on opening any time soon. lately I've been on an Anti-Seize kick, I like it because it doesn't let the gasket stick in spots & tear during torqueing like those silicone beaded $ gaskets do, allows for mistakes & re-do's if the intake has to come off again soon but it seals well too. last intake I did the Anti-Seize ended up being on a lot longer than I figured it would & had no issues for the duration of several years, & the gaskets still peeled off nice good enough to re-use. Hylomar is an option, non-hardening, removable within reasonable timeframe. I've also used Spray Copper on the paper gaskets, Gaska-cinch(rubber cement) on a 2nd time turkey pan... one thing I don't like about the turkey pan is that there's no seal (unless you know & do it on purpose) on the top side of the pan & the intake ends. I found condensation & rust pinholes in the last turkey pan I did after a fairly short period, that's the tray that ended up being the heat shield & why it's painted I just wiped the link I had posted for the FelPro 1240 intake set because it's the silicone bead style, http://www.summitracing.com/parts/fel-1240/overview/make/ford" rel="nofollow - http://www.summitracing.com/parts/fel-1240/overview/make/ford they stick, pull & distort during torqueing to the extent that the they destroy themselves & leak, http://www.network54.com/Forum/119419/thread/1355973452" rel="nofollow - http://www.network54.com/Forum/119419/thread/1355973452 http://www.network54.com/Forum/119419/thread/1343607818" rel="nofollow - http://www.network54.com/Forum/119419/thread/1343607818 whatever the trick is to getting them snugged down clean I don't know it & for that reason I avoid the silicone bead from any gasket company. I've heard to use WD40 on the metal but that doesn't sound right to me? I know WD40 doesn't last like gear lube but still this is one case where I go to the bargain aisle for the Mr Garbage paper gaskets, I'm all over MRG-222 or equivalent on this one, just simple basic composition paper material http://www.summitracing.com/parts/mrg-222/overview/make/ford" rel="nofollow - http://www.summitracing.com/parts/mrg-222/overview/make/ford the pic is showing the crossover block-offs but you can make them out of pop can metal or whatever, old turkey pan metal?. I'd use just a dab of whatever kind of gasket goo you're feeling at the time to hold them in place on the head so the exhaust only sees the metal block-off to protect the gasket I do tend to read 351C.net quite a bit
------------- 72 GT Ute
