Print Page | Close Window
Lug nuts
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=1384
Printed Date: 26-March-2026 at 3:54PM
Topic: Lug nuts
Posted By: TomiTomi
Subject: Lug nuts
Date Posted: 16-March-2008 at 5:54AM
I'd like to buy http://store.summitracing.com/partdetail.asp?autofilter=1&part=ARE%2DA695865&N=700+115&autoview=sku - Ansen Sprint rims . And at the same time I'd like to buy appropriate lug nuts for it. It's clear that the seat is conical, 60 degrees. But what is the correct thread size?
These are offered at Summit Racing:
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900388 - 14mm x 1.50 RH
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900366 - 1/2-20 RH in.
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900402 - 12mm x 1.50 RH
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294902769 - 7/16-20 RH in.
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900358 - 9/16-18 RH in.
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900374 - 12mm x 1.25 RH
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900341 - 14mm x 2.0 RH
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900331 - 12mm x 1.75 RH
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900348 - 9/16-18 LH in.
  • http://store.summitracing.com/egnsearch.asp?N=700+4294919065+4294755956+4294902780+115+4294900327 - 10mm x 1.25 RH
Could you please help me to choose the correct one?
Thanks, Tomi
Tomi
______________________
http://www.ford-cruising.hu/gallery/thumbnails.php?album=31" rel="nofollow - 1975 Ford Gran Torino S&H
2005 Ford Mustang GT
2011 Ford S-Max
Posted By: stuck
Date Posted: 16-March-2008 at 4:23PM
i was happy to see 1 chojce for 1/2.  my 72 uses 1/2
michigan
Posted By: stuck
Date Posted: 16-March-2008 at 4:46PM
   i see why that was a hard question for me ,it was to easy. yes definitely 1/2 possibly all as far as i know all 60s and 70s u.s. fords were 1/2 inch. you could have narrowed it down because there are no metric nuts or bolts on your car.guess you have starsky and hutch torino.like the aluminum slots always have.if your trying to be correct with the car i think it had wider wheels in back.always smart all 5 same size for driving car.   i would ask the company that makes the wheel for a suggested lug nut,but bieng conical sounds like they eliminated the issue that concerned me.but you should still ask them ,i dont think the correct lug nut will look like a steel wheel nut.  460  i like.
michigan
Posted By: Eliteman76
Date Posted: 20-March-2008 at 4:46PM
Tomi-
As long as no one else has replaced the wheel studs on the car, the thread is the 1/2-20 thread. Most fords on the older RWD and trucks have that thread; All 3 of my 1972 torinos, my 5 Ford Elites, my '77 Thunderbird, and my three ford trucks have had that thread.
Andy
Posted By: Torinogts73c
Date Posted: 20-March-2008 at 5:30PM
+1
Posted By: TomiTomi
Date Posted: 24-March-2008 at 11:52AM
Thanks to you all.
Tomi
2011 Ford S-Max
