Print Page | Close Window
C4 transmission separator plate??
Forum Name: Transmissions
Forum Description: For discussion relating to all Ford Transmissions
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=13911
Printed Date: 26-March-2026 at 5:53PM
Topic: C4 transmission separator plate??
Posted By: Keith_84
Subject: C4 transmission separator plate??
Date Posted: 01-June-2015 at 12:21PM
I am changing out my torqe converter and i am wondering if I need the transmission separator plate??? If so does anybody reccomend a peticular brand for a 72 gts? Trans's are kinda foreign so any suggestions would be appreciated!
Posted By: 75GranMan
Date Posted: 01-June-2015 at 1:58PM
Yes the separator plate is needed for spacing( converter to flywheel). It's possible to jam the converter into the flywheel if the plate isn't used. always check when bolting the trans to the engine, that the converter isn't forced to the flywheel. I usally grab a converter stud and make sure it moves in the flexplate stud hole.
Date Posted: 01-June-2015 at 2:00PM
The shield is also a pilot for the starter mount as well.
