Print Page | Close Window
3 speed v.s 4 speed parts
Forum Name: Transmissions
Forum Description: For discussion relating to all Ford Transmissions
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=14746
Topic: 3 speed v.s 4 speed parts
Posted By: kversch
Subject: 3 speed v.s 4 speed parts
Date Posted: 13-February-2016 at 6:12AM
Hey guys. Other then the transmission .   Are there any differences is the parts on a three speed vs a 4 speed?      I've seen a few three on the tree cars come up for sale recently.   It's got me wondering about parts interchange for doing the four speed convention.
-kevin-
Brown 72 gran torino 351c 2v
Black 73 GTS FB 302
Red 73 GTS FB 351C C6 trans
73 GTS FB Parted
97 F250 crew cab 7.3 diesel
Posted By: Rockatansky
Date Posted: 13-February-2016 at 6:57AM
pretty sure the clutch linkage parts are the same for each given engine combo, small bell pattern vs large
FE you're on your own
now I wonder if the frame mounted pivot is always the same?
Posted By: 75GranMan
Date Posted: 13-February-2016 at 10:50AM
I've never have seen a floor shifted 3spd 72/73 torino, pretty sure all were 3 on the tree. I also believe the 3spd speedo cable entered from the left side of the trans?
Date Posted: 13-February-2016 at 1:15PM
if the speedo is on the left it's the same cable & driven gear as an automatic,
RUG 4 speed uses a longer cable & opposite rotation driven gear for a right side connection
Posted By: kychevyguy
Date Posted: 13-February-2016 at 1:30PM
The big difference is the three on a tree has the shifter on the steering column while the four speed has the shifter on the floor. LOLLOLLOL
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Posted By: GTW
Date Posted: 13-February-2016 at 2:35PM
3 speed cars are rarer than 4 speed cars...
Posted By: 72sport
Date Posted: 14-February-2016 at 2:30AM
Clutch pedal and linkage are the same between 3 and 4 speed.  3 speeds were all column shift, so you'd need a column and tunnel hump to look correct.  Reverse wire harness for backup lights to make those work.  I'm not sure on  the speedo cable.  I'm not 100% sure, but about 95% sure driveshaft length is the same.
Tom
1972 Gran Torino Sport 4Spd
Posted By: kversch
Date Posted: 14-February-2016 at 1:24PM
This is what has got me thinking about this check this car out.     They have converted the three on the tree to a floor shift.
https://binghamton.craigslist.org/cto/5407613874.html" rel="nofollow - https://binghamton.craigslist.org/cto/5407613874.html
-kevin-
Black 73 GTS FB 302
73 GTS FB Parted
Posted By: MrSmog
Date Posted: 14-February-2016 at 4:44PM
he's sure proud of that 4 door
Posted By: Big Bird
Date Posted: 15-February-2016 at 11:19AM
kinda like it...
Base 4-door with a stick.
Don't think I like it at $4k...
maybe half that.
Posted By: MrSmog
Date Posted: 15-February-2016 at 11:57AM
kinda like it...
maybe half that.
yea has that bootlegger look to it, gator McKlusky tribute? lol
Posted By: unlovedford
Date Posted: 16-February-2016 at 4:31AM
Other than swapping the 3 speed manual column out and cutting a hole in the hump on my base wagon, pretty much everything else is straightforward to swap in a 5 speed. Pedals are there, Z bar, etc. My preference would be to use the Fox clutch/pedal setup I have with a cable for smoother action, which I may do. That would leave me with a couple of complete sets of 4 speed changeover components for a future project.
Posted By: inenidok
Date Posted: 22-February-2016 at 4:09PM
I just got manual steering gear box and pedals and z bar and linkage out of a 73 torino 3 on the tree
