Turn signals
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=18588
Printed Date: 26-March-2026 at 7:26AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Turn signals
Posted By: zjosh
Subject: Turn signals
Date Posted: 17-January-2020 at 2:05PM
In need of a bit of some trouble shooting help.. I'm reinstalling new wiring and I was testing the turn signals. The front and back lights light up but do not flash. I have new bulbs and new flasher fuses.
Any ideas??
Thanks Tom
Posted By: californiajohnny
Date Posted: 17-January-2020 at 4:58PM
basically keyed power goes into one terminal of the flasher, the other term. of the flasher goes to the common input to the turn sig. switch! as you move the switch to one side it draws power through the flasher and also disconnects the brake light on that side so it can flash only that side allowing the opposite brake light to still operate. if that makes sense? also check that the hazard 4 way isnt engaged... sometimes that can mess things up if not wired all correctly
Date Posted: 17-January-2020 at 5:01PM
another thought... if all the lights are lighting correctly but not flashing... are you running all new LED bulbs??? if so you'll need a no-load LED flasher as led's don't draw enough current to heat up a standard flasher
Posted By: zjosh
Date Posted: 17-January-2020 at 11:52PM
What if the break light are not hooked up yet? Will that cause the problem?
Tom
Date Posted: 18-January-2020 at 5:44AM
hmm i don't think that should matter since they use the same wire and element in the bulb... as you said the lights light up both front and rear but don't flash
Posted By: hogfiddles
Date Posted: 19-January-2020 at 12:49PM
was that while car running or not? I’ve had vehicles in the past, and many bikes this way.... it must be running for the correct resistances to trip the flashers. Just something to consider——
Dfox
------------- 1973 Gran Torino Sport - Q code “Q-Clone” project-on-hold 1972 Gran Torino Sport - Q code new project 1972 Gran Torino - parts 1969 Torino GT - M code 100+ mid-80's Yamaha XJ-Series (14 trophies)
Posted By: zjosh
Date Posted: 20-January-2020 at 4:02AM
Right now the car does not run. But if we are getting full power and the light do light up nice and bright in front and in back I would think there is enough power. ???
Posted By: Rivercrest
Date Posted: 20-January-2020 at 8:33AM
Putting a test bulb (1157?) between the flasher output and ground would help eliminate a few possibilities if the bulb flashes.
Date Posted: 20-January-2020 at 12:33PM
it sounds like you bypassed the flasher somehow in your wiring???
