Ford 9" Housing Drain
Forum Name: General Automotive Technical Discussion
Forum Description: Technical Automotive discussion of anything not specific to mid-size Ford/Merc
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=18625
Printed Date: 28-March-2024 at 7:39PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Ford 9" Housing Drain
Posted By: 72FordGTS
Subject: Ford 9" Housing Drain
Date Posted: 07-February-2020 at 2:01PM
I have my rear axle apart right now and was thinking of installing a drain on the housing. Does anyone have recommendation for one that doesn't require welding?
------------- Vince
Posted By: californiajohnny
Date Posted: 07-February-2020 at 2:43PM
i drilled and tapped both of the rearends that were and are in my car
1/8" NPT
Date Posted: 07-February-2020 at 2:46PM
Posted By: handsofstone
Date Posted: 07-February-2020 at 5:03PM
you can do up to 1/2 inch I believe. Then get a plug with hex hole fir flush fit. Might find one with a magnet as well.
Date Posted: 08-February-2020 at 7:32AM
I didn't think the housing material was thick enough to tap. Did you just use a 1/4 NPT plug? Any gasket required?
------------- Vince
Date Posted: 08-February-2020 at 8:09AM
I would use Rector Seal or Lue Magic. I suppose you could use a couple wraps of teflon tape too. When I resealed the duff I didn't think to add a drain. Sure keeps the floor a little cleaner. Lol
Date Posted: 08-February-2020 at 8:35AM
it's about 1/8" thick . remember NPT is tapered so only run the tap about half way in i used a brass hex plug and a wrap of teflon tape no leaks i drilled on the passenger side just up from the flat bottom part (away from the ring gear, away from where you'd put a jack) 1/4NPT or 1/8NPT will work
going 3/8 or 1/2 would be too large of threads in that thin housing
Date Posted: 08-February-2020 at 8:39AM
actually looking at that pic... i used 1/8 NPT tap and plug
Date Posted: 08-February-2020 at 9:27AM
We drilled and plugged torque converters with 1/8" brass plugs after flushing.
