painting magnum rims
Category: General Discussion
Forum Name: Auto Body Forum
Forum Description: Discussion of anything related to body, paint and metal work/restoration
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=18990
Printed Date: 28-March-2024 at 10:16PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: painting magnum rims
Posted By: oldgold69
Subject: painting magnum rims
Date Posted: 22-July-2020 at 6:00AM
I know this is a simple answer but are the painted gloss or flat black or do you paint it gloss then try and get it to flatten a little thanks for any help then there is another question on the quarter panel seam the car had plastic filler in the seam it was a vinyl top car rust lifted the filler out of the seam I was thinking if I welded the seam shut prime it and then put a metal patch in the seam then skim coat it with filler do you think it would crack at the seam I thought if I closed the seam it wouldn't rust it is heavily pitted now the rest of the roof just surface rust thanks jim
Posted By: californiajohnny
Date Posted: 22-July-2020 at 1:22PM
IDK i think the wheels were semi-gloss?? if spaying it with a gun... you could add some flattening agent to the gloss paint then spray...
weld the seam solid then use duraglas filler not regular filler! yes you can weld a patch in flush to cover the seam
Date Posted: 22-July-2020 at 3:38PM
thanks for the reply that help with the rims the seam would be filled with about a half an inch of filler I just thought that would be too thick and would shrink in time I would put in in thin layers and let it set good but if i fill the seam with metal it shouldn't shrink as bad it will be a painted roof thanks jim
Date Posted: 22-July-2020 at 3:43PM
ok if it's that deep, I'd trim a piece of sheet metal to fit over the whole seam flush, welded and ground smooth then body filler to blend it all perfect
