Manifold bolt?
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=20286
Printed Date: 19-April-2024 at 10:22AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Manifold bolt?
Posted By: Anderslober
Subject: Manifold bolt?
Date Posted: 22-July-2022 at 8:22AM
Hi forum…qq…exhaust manifold…right side…..is there supposed to be a bolt on one side where the exhaust pipe hooks up?
I had a great fight today…..still havent won!😵👍
Posted By: Rockatansky
Date Posted: 22-July-2022 at 10:43AM
should be 2 studs / nuts
------------- 72 GT Ute
Date Posted: 22-July-2022 at 7:35PM
Ok. Thanks. Someone drilled a hole for a bolt then. The other studs are not in great condition. Can they be removed and changed?
Date Posted: 23-July-2022 at 2:43AM
Date Posted: 23-July-2022 at 3:15AM
this is the Dorman number that pops up on Rockauto for our exhaust manifolds but there may be longer studs available so check what length will work for you, and verify the method of obtaining that measurement. or you may be able to source some locally? http://www.rockauto.com/en/moreinfo.php?pk=1261582&cc=1129306&pt=13936&jsn=570" rel="nofollow - https://www.rockauto.com/en/moreinfo.php?pk=1261582&cc=1129306&pt=13936&jsn=570
Date Posted: 23-July-2022 at 3:42AM
Wow…wax…who knew!👍 I will see what I can do.
Date Posted: 24-July-2022 at 1:31AM
Here are some pictures my cars’ right manifold….
Date Posted: 24-July-2022 at 1:32AM
Date Posted: 24-July-2022 at 1:33AM
And another…(I still dont know how to upload more than one photo in a post)
Posted By: handsofstone
Date Posted: 24-July-2022 at 5:10AM
Anderslober wrote:
And another…(I still dont know how to upload more than one photo in a post) | Just repeat the download procedure before you post reply and they will all be in the same place.
Date Posted: 26-July-2022 at 9:35PM
Ssshhhhuuuuccckkkss! I tried to take of the right exhaust manifold. All went well, until the very last number one cylinder upper bolt….snap….. Anyway….maybe still possible to get the bolt…..will post…
Posted By: 72 RS 351
Date Posted: 27-July-2022 at 3:36AM
Tip, just barely brake loose all related bolts before fully loosening any of them. The extra pressure from having some bolts out adds slightly to the others.
Date Posted: 27-July-2022 at 11:27AM
are you working the bolts back & forth (tight / loose) and lubing as you go?
1st move should be in the tight direction, then check it in the loose direction.
smack the bolt head with a hammer and test each direction again.
a 1/2" breaker bar with a quality 6 point socket is the way to go, a metric socket that fits tight beats a loose inch socket every day of the week
Date Posted: 27-July-2022 at 6:16PM
A six point with the little grooves at the angles will be the best bet adding to what Rock posted. Especially if they are slightly rounded off.
Date Posted: 28-July-2022 at 4:32AM
Those socket and wrenches with the rounded corners used to be a Snap-On invention. Now even the cheap China tools have them.
Posted By: Big Bird
Date Posted: 28-July-2022 at 6:40AM
radiused corners don't really help the bolt come loose, Snap-Off patent was to reduce stress risers and broken sockets/warranty costs. They have dazzled everyone with bullsh*t about "Flank drive" for years.
Date Posted: 28-July-2022 at 7:55AM
I was very careful during the operation. Yes….I slightly tightened first….then loosened…back and forth…carefully…used a full can of wd40 type fluid.The last bolt was just unlucky. The bolt looked different than the others. Greyish burnt and rough.
Date Posted: 28-July-2022 at 12:44PM
Anderslober wrote:
The bolt looked different than the others. Greyish burnt and rough. |
probably chinesium
Date Posted: 28-July-2022 at 10:25PM
If I am unable to find a right side manifold…..what is a good way to fix the drilled hole for the stud? Ideas welcome. The manifold looks really good otherwise..
Date Posted: 29-July-2022 at 2:24AM
There are repair items made to replace a broken and seized stud etc. Find those and see if they will fit onto that one side. The one I'm thinking of is like a pair of steel bars that attach by long bolts of their own, sandwiching the ear of the collector and lower flange. Kind of like a clamp, it squeezes the old flanges(the small section where the bolt is) together with the down pipe flange. They are on Amazon and I think they were about a $25 item. I believe it requires a decent flat surface on both parts to clamp onto, but you can grind and file down that worn hole area to do that.
Date Posted: 29-July-2022 at 9:43AM
exhaust manifold split repair flange search results, images
http://www.google.com/search?q=exhaust+manifold+split+flange+repair&tbm=isch&ved=2ahUKEwjNjLPi9575AhVAkGoFHW3tD8sQ2-cCegQIABAA&oq=exhaust+manifold+split+flange+repair&gs_lcp=CgNpbWcQDDoFCAAQgAQ6BAgAEBhQhBFYjB9gmjpoAHAAeACAAb0BiAHTBZIBAzUuMpgBAKABAaoBC2d3cy13aXotaW1nwAEB&sclient=img&ei=zULkYo1ywKCq2w_t2r_YDA&bih=871&biw=1280&client=firefox-b-1-d" rel="nofollow - https://www.google.com/search?q=exhaust+manifold+split+flange+repair&tbm=isch&ved=2ahUKEwjNjLPi9575AhVAkGoFHW3tD8sQ2-cCegQIABAA&oq=exhaust+manifold+split+flange+repair&gs_lcp=CgNpbWcQDDoFCAAQgAQ6BAgAEBhQhBFYjB9gmjpoAHAAeACAAb0BiAHTBZIBAzUuMpgBAKABAaoBC2d3cy13aXotaW1nwAEB&sclient=img&ei=zULkYo1ywKCq2w_t2r_YDA&bih=871&biw=1280&client=firefox-b-1-d
Date Posted: 29-July-2022 at 10:05AM
That's a large variety of repair solutions for broken or stripped manifold studs and bolts.
This is the type I was thinking of. I thought it clamped the two parts together, but it just replaces the manifold stud with an interesting loop of steel; https://www.amazon.com/Exhaust-Manifold-Repair-Studfix-FC8001/dp/B0B34D8JGL/ref=sr_1_11?crid=20XC1KY9H7YCP&keywords=Exhaust+Manifold+Repair&qid=1659128469&sprefix=exhaust+manifold+repair%2Caps%2C1808&sr=8-11" rel="nofollow - https://www.amazon.com/Exhaust-Manifold-Repair-Studfix-FC8001/dp/B0B34D8JGL/ref=sr_1_11?crid=20XC1KY9H7YCP&keywords=Exhaust+Manifold+Repair&qid=1659128469&sprefix=exhaust+manifold+repair%2Caps%2C1808&sr=8-11
Date Posted: 29-July-2022 at 3:48PM
Get a straight torch tip and burn out the stud. Tap the threads. Put the rest of the bolts back in first. If the manifold hasn't moved, it will still be sealed to the head.
Posted By: californiajohnny
Date Posted: 30-July-2022 at 12:55PM
its drilled out...i's rethread it, or if needed drill it larger and helicoil it to the correct size, or since there's room use a bolt that is long enough to go down towards the pipe (grind part of the bolt head to fit against the manifold)
Date Posted: 02-August-2022 at 8:22AM
I got the right exhaust manifold off today. No bloody gasket!
Date Posted: 02-August-2022 at 8:24AM
Manifold looks good. Except the drill out hole…
Date Posted: 02-August-2022 at 1:13PM
Ford didn't use gaskets on the X manifolds
Date Posted: 02-August-2022 at 7:48PM
Wow…ok….that means this is original and untouched basically.
I think I will put in a gasket though….
Date Posted: 03-August-2022 at 12:58AM
Whadyasay fellas..? Just need an angled washer now…..
Date Posted: 04-August-2022 at 7:42AM
Run a tap and use a heli-coil (there is a better coil replacement system but I forget the name). That setup will work but you already have the manifold out so why not do the other one as well?
Date Posted: 04-August-2022 at 8:40AM
I had to drill out the other side today. Bolt snapped after heating, whacking, drenching. No worries.
Yes….tapping…..what measurement are the studs? 5/8? I will try and tap for that.
Date Posted: 04-August-2022 at 12:19PM
I doubt you will be satisfied with threads tapped into a cast iron manifold, that might be a last resort I'd consider.
Date Posted: 06-August-2022 at 5:39AM
IIRC the replacement studs are 7/16-NC (National Course)
7/16"-14 x 2-1/4" to be exact
http://www.rockauto.com/en/catalog/ford,1974,gran+torino,5.8l+351cid+v8,1129306,exhaust+&+emission,exhaust+flange+stud+and+nut,13936" rel="nofollow - - https://www.rockauto.com/en/catalog/ford,1974,gran+torino,5.8l+351cid+v8,1129306,exhaust+&+emission,exhaust+flange+stud+and+nut,13936
http://www.dormanproducts.com/p-353-03099.aspx" rel="nofollow - https://www.dormanproducts.com/p-353-03099.aspx
http://www.amazon.com/Dorman-03099-Exhaust-Flange-Hardware/dp/B00068OIFO" rel="nofollow - - http://www.amazon.com/Dorman-03099-Exhaust-Flange-Hardware/dp/B00068OIFO" rel="nofollow - https://www.amazon.com/Dorman-03099-Exhaust-Flange-Hardware/dp/B00068OIFO
Date Posted: 18-August-2022 at 8:27PM
Today is the day, where I will attempt to remove the 3 snapped bolts. 2 manifold bolts and 1 engine mount bolt. Should be fun. I dont have any welding equipment, so I will drill and use easy out.
Date Posted: 19-August-2022 at 7:24AM
while you have the pan off, very important!, change the connecting rod nuts
they're garbage, the threads fracture out under stress
all you have to do is remove, replace, torque to spec 40-45 lb-ft IIRC
16 pieces required
Date Posted: 19-August-2022 at 8:17AM
Timing chain has to go as well as a new oil pump. No going back now as you are in it to win it.
Date Posted: 19-August-2022 at 9:35AM
do you have an acetylene torch? heat the bolt till its starting to get a spot of orange than they come out
Date Posted: 19-August-2022 at 10:57AM
