1970 Ford Fairlane 500 / Torino Parts
These are parts left over from the restoration of my 1970 Torino sedan. Most are from a Fairlane 500 parts car which I used to own. I can take and send pictures for you. All parts
are “or best offer”.
Buyer pays
shipping.
Contact Dan
at dcutler@mi.rr.com if you have questions or would like to buy parts.
2-barrel
carb $50
Steering
column $50
(2)
GT hood scoops without chrome inset bezel $50 each
“F”
“O” “R” emblems $5 each
(3)
voltage regulators $10 each
(2)
front door interior armrest brackets (chrome) $20
Black
arm rest $10
(2)
black front ash trays $20 each
Black
rear ash tray $20
Glove
box interior $20
Black
glove box door $20
Black
sun visors (LH & RH) $20 each
Black
sun visor clip $10
(4)
dash panel vents $10 each
Black
plastic trim panel behind door (RH) $20
Black
rear interior corner piece sedan (LH) $20
Black
plastic steering shaft cover $20
(3)
chrome interior door handles $10 each
Turn
signal stalk $5
Interior
door latches and misc parts $10 each
Misc
window cranks $5 each
Weatherstrip
clips full set $5
Side
window nuts $5
Flasher
clip $5
Steering
column bolts $5
Body
vent on door jamb $5
Steering
wheel center emblem $5
Headlight
aiming screws $5 each
(2)
rear side marker lights (RH) $20 each
(2)
front side marker lights (LH) $20 each
(2)
front side marker lights (RH) $20 each
Front
side marker light wire $5
Dash
panel to steering column seal $20
Black
valve cover breather $20
(2)
front door manual window regulators $50 each
(2)
rear door manual window regulators $50 each
Black
upper back trim panels (over rear seat) – sedan $20 for pair
Misc
bright trim parts around windows sedan Call
(2)
windshield wiper arms $10 each
Brake
pedal for disc brakes $10
(3)
horns $5 each
“Fairlane
500” emblems (LH & RH) $50 for set
Trunk
lock and striker $20
Upper
radiator support brackets $10 each
Torque
converter to flex plate nuts $5
Ford
lug nuts – full set $10
Cowl
windshield supports at base of windshield $20
License
plate light $20
Oil
vent breather for valve cover $20
Vacuum
port on cowl $10
Fuel
cap to body gasket $20
(6)
head light buckets $10 each
(4)
outside door handles $20 each
Hood
striker $20
Hood
vent at rear of hood $20
Rear
license plate bracket $20
Rear
bumper brackets with bolts (LH & RH) $20 each
Engine
hoist attachments for 302 V8 $10
(2)
front fender extensions (LH) $20 each
(2)
front fender extensions (RH) $20 each
Front
under grille fender extension $20
(2)
sedan rear fender extensions $20 each
(2)
sedan taillights (LH) $50 each
Sedan taillight bezel (LH) $50
Sedan taillight with bezel (RH) $50
Sedan taillight bezel (RH) $50
Front
fender baffle (LH) $20
Front
fender baffle (RH) $20
