Print Page | Close Window
68 Torino fuel line venting
Forum Name: 1968-1969 Ford and Mercury
Forum Description: Technical discussion for 1968-1969 Ford and Mercury
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21006
Printed Date: 26-March-2026 at 5:43PM
Topic: 68 Torino fuel line venting
Posted By: ironhorse
Subject: 68 Torino fuel line venting
Date Posted: 11-November-2023 at 3:53PM
Hi does anyone have pics of fuel line venting, have a big block convert, have a couple of cars apart for a few years and want to make sure I have the correct pieces, thx jim
Posted By: schufitz
Date Posted: 12-November-2023 at 7:06AM
Below is the set up on my 69 formal with 351W.  I believe all engines are the same.  There's a rubber hose shaped like a large "F' that takes the 2 vent ports from the tank to go into one metal line that runs along back taillight panel, up and around behind the rear light housing then down through a grommet on the trunk floor and connects to a rubber tube that vents to atmosphere.  That hose end is stuck into frame rail.  Mine had a replacement tank when I got the car.  The tank has just 1 port, so one of the 'F' hose ends is plugged with a screw.
Date Posted: 12-November-2023 at 1:51PM
That is awesome, thx for the reply, you don’t know how long I’ve looked around on the internet for some pics, thx for taking the time and sending all the pics I need,  one more step closer to being finished , thx again
Posted By: blitzkrull
Date Posted: 15-April-2024 at 12:57AM
My 69 Torino has the same configuration except mine is not connected up by the taillight as yours is pictured. Instead, it lays alongside the inner fender. I’m guessing this is why when I fill up my tank, fuel gets vented out of that tube once pressure from the fumes and expansion of the fuel has occurred. Thanks for the pics!!
