Print Page | Close Window
Bolt pattern C6/FMX on 351w
Forum Name: Transmissions
Forum Description: For discussion relating to all Ford Transmissions
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21136
Printed Date: 26-March-2026 at 3:54PM
Topic: Bolt pattern C6/FMX on 351w
Posted By: tedthemechanic
Subject: Bolt pattern C6/FMX on 351w
Date Posted: 12-February-2024 at 3:49AM
Hey guys,
Im putting in a fresh 351w and ive found a place i can get a fresh C6 transmission. I just want to make sure the bellhousing bolt patterns are the same before i purchase the trans. My car is a 1975 Gran Torino 351w.
Thanks in advance for any info.
Ken  .
If it wasn't for the home of the Brave,there would be no land of the Free !
Posted By: Inkara1
Date Posted: 12-February-2024 at 9:56AM
The C6 came in three versions, which could mount to the big block pattern (351M/400/429/460), the 1965-up small block pattern (289, 302, 351W, 351C), or the FE pattern (332, 352, 360, 390, 406, 410, 427, 428). You can't change the bellhousing like you can with a C4 or FMX, so make sure you get the right one. My car has a 351C with a C6 a prior owner installed.
Posted By: Inkara1
Date Posted: 12-February-2024 at 10:01AM
I found an image to show how to tell them apart:
Posted By: Rockatansky
Date Posted: 12-February-2024 at 11:41AM
"The C6 was used in trucks and cars with larger engines,
Five different bell housing varieties exist for use with various Ford engine families:
1) The Windsor pattern was used on the 300 I6, the Ford Windsor engines and the 351 Cleveland
2) The 460 pattern was used on the 351M and 400 and all of the Ford "385" engines
3) The FE pattern was used on the FE engines
4)The rare 66 - 68 Lincoln MEL 462 pattern which was used on 66 - 68 Lincoln Continentals with the    462 engine and also on 68 - 69 Lincoln Continentals with the 460. This pattern rounds off on the passenger side to clear the heat/AC box on the 66 - 69 Lincoln firewall
5_Diesel pattern. This was similar to the FE/"385" pattern but the two are not interchangeable"
https://www.transdepot.net/c6transmissions" rel="nofollow - https://www.transdepot.net/c6transmissions
