Print Page | Close Window
Headlight installation
Forum Name: 1970-1971 Ford and Mercury
Forum Description: Technical discussion for 1970-1971 Ford and Mercury
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21343
Printed Date: 26-March-2026 at 5:43PM
Topic: Headlight installation
Posted By: Oden1543
Subject: Headlight installation
Date Posted: 11-July-2024 at 4:51PM
Okay I know this sounds dumb but I'm having issues installing my headlights on my 1971 torino base model. I know I'm installing them right since I successfully reinstalled the old lights it had, but after picking up 2 different types of headlights I ordered from O'Reillys I wasn't able to install either of them. Also I have no real car knowledge. This is my first ever project car. Any type of help is thanked. These are the 2 different headlights I got.
Sylvania H5001 Basic Sealed Beam Headlight Bulb (Pack of 1) - H5001
Sylvania H5006 Basic Sealed Beam Headlight Bulb (Pack of 1) - H5006
Posted By: peter.jenerette
Date Posted: 12-July-2024 at 4:14AM
Can you better describe what is giving the issue. Hi Beams and Hi/Low beams cannot be switched; there are also locating dimples on the headlights..this is a diagram from a GTO, but should give you further insight...
Posted By: Oden1543
Date Posted: 12-July-2024 at 2:59PM
 I didn't know there was a difference between the lowbeam and hibeam headlight bracket. I will try installing the headlight onto a different bracket next time. I think I might of been trying to install the hi-beam headlight onto a low-beam headlight bracket.  Also thanks for the quick response, I really appreciate  it.
Posted By: 72FordGTS
Date Posted: 14-July-2024 at 1:19AM
The high beam lights, which only have two terminals, go on the inside.  The Hi/Lo beam bulbs, which have three terminals go on the outside.  I assume you were able to get the retaining rings off okay?  Lots of people mistakenly use the headlight adjustment screws in error.
Posted By: Oden1543
Date Posted: 14-July-2024 at 5:23PM
I somehow managed to get it right without knowing the highbeams go on the inside. I appreciate all the help, thank you.
