Print Page | Close Window
SUCCESS Removal of Factory intake drive screws
Forum Name: Big Block Engine Forum
Forum Description: 429 and 460 engines
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21436
Printed Date: 26-March-2026 at 9:20AM
Topic: SUCCESS Removal of Factory intake drive screws
Posted By: TV 2M8O
Subject: SUCCESS Removal of Factory intake drive screws
Date Posted: 21-October-2024 at 2:50AM
OK guys, got the sandblasting cabinet back on line Saturday so I'm now ready to start reblasting a few previously detailed parts and get them back to looking good. In addition to those pieces, I also have a factory D0OE 429 CJ intake (man THAT MUTHA IS HEAVY) I want to get cleaned up to install on the original 460 that came in my Torino once I get it rebuilt using mildly ported C8VE heads and possibly a roller cam... all that is still up in the air.
The reason for this post is there is a stamped steel "carb isolation plate" (?) mounted to the underside with three drive screws. I was hoping to drive a thin blade between the plate and manifold and gradually wedge the plate and drive screws off the manifold but after 54 years together, they're pretty stubborn to separate. The plate isn't very thick so it won't take too much persuasion, so was hoping someone might have a way of extracting the drive screw "easily".
All suggestions appreciated!!
THANKS
Posted By: TV 2M8O
Date Posted: 27-October-2024 at 2:47AM
SUCCESS!!
Since I didn't get any suggested method of removing the drive screws, I just jumped in and tried what sounded like should work...
Trial #1: Tried using a vice grip to bite into the screw head, but since it was a round headed drive screw, there wasn't enough edge to get a good grip on, so using a cutoff wheel, I cut a groove in the center of the head to see if using a large blade screwdriver would work. Sadly all it did was roll out the groove.
Trial #2: I grabbed my can of KROLL and shot each screw with a bit of penetrant and let them soak for about 15 minutes before trying again. I next took the cutoff wheel and cut off each side of the slotted drive screw head about the with of what I though the screw body might be and then tried again to grab the head of the screw with the vice grip but because my cuts weren't exactly parallel, the vice grip kept popping off.
Trial #3: With the edges of the first drive screw not flat, I took a good sized pin punch and hammer and started driving the screw ccw to get the teeth from releasing. I could see that the head was turning but because of the initial slot cut into the head, only the head was turning and finally broke free of the screw body.Angry
Trial #4: On the next screw, I again took the cutoff wheel and trimmed off the sides of the head to again give me a flat surface to work from. Tried the vice grips again and had the same result as before because the side weren't parallel, so took the hammer and punch and began driving the screw ccw and could see the head slowly turning. After a few more taps, I heard the thin metal shield "ting" so I figured the it might now be loose enough to use the vice grips on it and VOILA the screw turned a bit and came right out intact!!
I repeated #4 again on the third drive screw and it came out just as easily as the previous screw did.
So the trick is to first hit the screw with some penetrant, let it soak in a bit, trim off one side of the drive screw to give you a vertical face to work against and then use a pin punch to drive the screw ccw to release the teeth.
If the area is really crusty, perhaps hit the screw with some heat to enlarge it slightly and break loose any rust that may be seizing the screw into the material.
Hope this is helpful to someone else in the future!
Posted By: 72FordGTS
Date Posted: 27-October-2024 at 6:04AM
Thanks for sharing Joe, I am sure this will help others out later on.
Posted By: aquartlow
Date Posted: 27-October-2024 at 9:21AM
Congratulations on their removal! I have a book that shows how to remove them-yeah just in time for this info huh? It shows to use a chisel to loosen the rivet, then take a pair of vice-grips to turn them counter-clockwise to remove them. I would use 1/4-20 x 1/2" or 5/8" bolts for re-attachment, using with 1/4-20 bottom tap first, I believe you won't even have to drill them since the rivet holes supposedly readily accept the 1/4-20 tap, don't forget the red loctite. Hope this helps
Posted By: TV 2M8O
Date Posted: 27-October-2024 at 9:52AM
Todd, I just plan on using new drive screws... I'll not ever be taking them out again!
Date Posted: 27-October-2024 at 10:17PM
Todd, I  just plan on using new drive screws... I'll not ever be taking the out again!
Thumbs Up
