Print Page | Close Window
Wiper Nozzle Attaching 70 Torino
Forum Name: 1970-1971 Ford and Mercury
Forum Description: Technical discussion for 1970-1971 Ford and Mercury
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21469
Printed Date: 26-March-2026 at 12:16PM
Topic: Wiper Nozzle Attaching 70 Torino
Posted By: Danno
Subject: Wiper Nozzle Attaching 70 Torino
Date Posted: 18-November-2024 at 9:11AM
Help! Anyone have a good picture that shows how and where to attach the metal nozzle? It looks like there is one screw per nozzle, but it is not obvious to me where and how it attaches to hood. I have a set of nozzles off eBay, no screws, so if you know the screw thread size please tell me.
Danno
Posted By: handsofstone
Date Posted: 23-November-2024 at 12:37PM
Paging @Californiajohnny
Posted By: Hinmaton
Date Posted: 16-May-2025 at 10:42AM
I don’t “know” the answer, but I just put some squirters on mine (Amazon plastic jobbies), and spent a bunch of time trying to figure out the original routing but found almost nothing. There are two pressed bosses on the underside panel of the hood with two holes; I believe one is for the screw and one is for the small tang on the OEM nozzle. From what I can tell, the spray lines came to a T or F shaped 3/16” barbed adapter on the driver’s side and then ran into a hole above to a T and then through the under hood panel and out again to a similar hole on the passenger side.
I hope this helps some, good luck.
Hinmaton
