Print Page | Close Window
Rear differential questions
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21566
Printed Date: 26-March-2026 at 5:43PM
Topic: Rear differential questions
Posted By: anchovieMAN
Subject: Rear differential questions
Date Posted: 31-January-2025 at 1:25PM
Hello I’m thinking about upgrading the differential in my 1973 Torino to a limited slip and there is also a big leak. I have a 4speed I plan on putting in it in the future. So my questions are what gear ratio should I go with and where should I buy from for quality parts?
Jayden
Posted By: pyntre
Date Posted: 31-January-2025 at 3:01PM
Quality / and great service for parts
Quick Performance out of Iowa . New center section and a new set of axles !
Gear ratio depends on many factors . Need a lot more info on what your driving patterns are , and how the car is going to be used .
Date Posted: 31-January-2025 at 4:07PM
I would like it to do 65-70 mph without the engine exploding. Just a daily driver and not overly worried about being fast
Jayden
Posted By: pyntre
Date Posted: 31-January-2025 at 4:49PM
Lots of RPM calculators that take rearend gear ratio , tire diameter and final trans ratio : ie, is it an overdrive transmission, into the equation . Plug those numbers in and you can dial in what you need !
Simple math , but it’s great when it all works together and you end up with a happy car , and driver !!
Posted By: 72FordGTS
Date Posted: 31-January-2025 at 9:11PM
With a 4-speed, you'd probably want a 3.25 to 3.50 ratio depending on your tire size.  Based on what your saying, maybe a 3.25 would be ideal for your needs.  Play around with the RPM calculators.
https://spicerparts.com/calculators/engine-rpm-calculator" rel="nofollow - https://spicerparts.com/calculators/engine-rpm-calculator
Summit has some complete center sections for 9" diffs, but they aren't cheap.
Posted By: handsofstone
Date Posted: 02-February-2025 at 4:16PM
I went with 3.25 in my car and long cruises at highway speeds had me finding backroads in no time.
Posted By: 72 RS 351
Date Posted: 03-February-2025 at 2:49AM
I didn't mind the 3.25's I put into my first 72 Gran Torino, it was okay for my all around driving. On long trips it would be a bit high rpm for good fuel economy.
The OD transmissions are all about .70:1 so highway rpm is 2000 at 70mph, using 3.25 gears. That's what my stock four Mark VII's have been, AOD and 3.27 gears, 26" tall tires. My 302 SUV's run 2000 rpm at 60mph, with 3.73 gears and 29"-30" tires. Anything in those ranges work great on the highway if you can put those together.
Date Posted: 03-February-2025 at 11:27AM
What was your RPM at highway speeds?
Don't forget he has a 4-speed, so there is no slippage like a torque converter.  Ford's optional or towing ratio for most engines in 1972 was 3.25.  3.25s were the base gear for Q-codes and 3.50s were optional.
Date Posted: 06-February-2025 at 2:19AM
I had no tach but 60 was the sweet spot. Above that it was in what I would call its power band and throttle response was instant.
