This Cobra has the numbers matching 428 CJ engine and C6 automatic transmission, and is in very good condition inside and out. I put over 1,000 miles on the motor driving on the weekends when the weather is good, easily cruising at 70+ miles per hour on the highway. She runs and drives great, idling at about 650RPM with a mean growl and rolling smoothly through the gears when accelerating. Go to the Hagerty's Auction for over 100 pics and videos: https://www.hagerty.com/marketplace/auction/1969-Ford-Torino/417c06be-de78-4934-8783-50eac8650636" rel="nofollow - https://www.hagerty.com/marketplace/auction/1969-Ford-Torino/417c06be-de78-4934-8783-50eac8650636 Highlights · Rebuilt Q-Code 428 CJ V8 with these upgrades: o Lunati cam (.574 lift) o Edelbrock Performer 750 cfm carb o Edelbrock Performer aluminum intake o Edelbrock Performer RPM aluminum heads o Aluminum water pump · Rebuilt C6 three-speed automatic transmission o Detroit Locker posi-traction rear end with 3.50:1 gears o 2,200 RPM stall converter · The Data Plate decodes as: o 63B - Cobra Two-Door Hardtop Fastback o B - Maroon Paint (now black) o 1 A- Black Broadcloth and Vinyl Bench Seat o 16D - Scheduled for Build 16 April 1969 o 61 - Dallas Ordering District o 6 - 3.00:1 axle ratio o U - CG Three-Speed Automatic Transmission · The chassis number (9R46Q166690) decodes as: o 9 -1969 model year o R- San Jose, California, final assembly plant o 46 - Cobra two-door hardtop fastback o Q - 428-4V CJ o 166690 - Plant sequential production number Features · About 8,000 miles on rebuilt engine · Power steering · Power front disc brakes (rear drum) · Trunk-mounted battery · After-market oil pressure, volt, and water temp gauges · Working factory tachometer · Nice carpet, headliner and dash pad · Solid original undercarriage, floorboards, frame and rockers · Rust-free body panels and trunk · Recent work in the last two years includes: o Rebuilt steering gear and power steering control valve o New master cylinder o New Champion aluminum radiator with electric cooling fans o New Edelbrock fuel pump o New plugs and MSD plug wire set o New Gates belts o New PowerMaster alternator o New Pertronix Flame Thrower ignition coil o New Pertronix Flame-Thrower electronic distributor (April 2025) o New lower control arms and upper ball joints o New KYB shocks o BF Goodrich Radial T/A tires with 1,000 miles (P225/60R15 Front, P245/60R15 Rear) o New halogen headlights o New high-beam floor button o New OE-correct window weather stripping o New window regulator in driver door o New gas cap Known Imperfections · A few minor rock chips in the paint, a nickle-size bubble at the top rear of the passenger quarter panel, a small bubble in the hood above the driver door, and a paint scuff above the driver taillight · Light scratches in the hood that can be buffed out · Front grill is off about .5 inch to the right of center · Most of the brightwork is original and shows expected patina and some minor dings · Small tear at the back of the drivers-side seat upholstery beneath the seat back · Radio, trunk light and factory clock are inoperable · Light windshield wiper scratch in driver-side windshield · No A/C components under the hood or air ducting behind dash, but blower and vents work fine Included · Original owner's manual · Two sets of keys · Ford 1969 Factory OEM Shop Manual (all volumes) print and digital · Chilton's Fairlane & Torino Repair and Tune Up Guide · Spare tire and jack · Extra fittings, clips, original rearview mirror, original distributor, and extra air filter
Let
------------- Kelly K 1969 Ford Cobra 428
