69 Ranchero hood latch
Forum Name: 1968-1969 Ford and Mercury
Forum Description: Technical discussion for 1968-1969 Ford and Mercury
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21830
Printed Date: 26-March-2026 at 9:20AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: 69 Ranchero hood latch
Posted By: jimh1956
Subject: 69 Ranchero hood latch
Date Posted: 05-October-2025 at 2:39PM
My 69 Ranchero has the hood latch stuck closed. Pull the handle and no disengagement. Is there a known solution? Thank you.
Posted By: jimh1956
Date Posted: 06-October-2025 at 9:55AM
Unbolting the latch brace was not successful, all of the bolts spun. Solution; unbolt the latch striker bar forward bolt and saw through the bar. Hood opens! Now I need a new bar.
Posted By: schufitz
Date Posted: 06-October-2025 at 2:56PM
Try to apply some downward pressure on the front of the hood as you pull the handle. Mine used to stick occasionally when I got it and that would work. I have since lubed up the moving parts and slightly adjusted the catch and it works good now. If that fails, you can remove the grill to access latch a bit. Thats a PITA. Need a 90 degree phillips (or ratchet) to get to center grill screws
------------- Dave 1969 Torino GT/351W 2V/FMX/Vinyl Top/Black Jade/Gold Stripes/Nugget Gold Buckets/Console/Racing Mirrors/AC/PS/PDB
Posted By: jimh1956
Date Posted: 14-October-2025 at 9:57AM
Thank you for the suggestion. Sawed through the latch bar, opened hood and removed latch. Turns out the latch was damaged as a small piece fell out. New latch bar was only available as part of next higher assy, now out of stock. Made a new piece from 7/16 dia. steel using blacksmithing techniques. New latch and new striker bar, now works like new.
Posted By: schufitz
Date Posted: 16-October-2025 at 7:50AM
